Layer freeze
Ribbon: Home – Layers > Layer freeze
Menu: Format – Layer tools > Layer freeze
Toolbar: Layers 2 –
Command line: LAYFRZ
Freezing the layers of selected objects. It makes these objects frozen both in model and paper spaces.
The commands freeze layers of selected objects only in a current viewport (if Viewports=Vpfreeze parameter is selected).
Settings | Switches to the selection parameters mode. Selected parameters are saved for the next session. The option starts the following prompt in the command line: Enter setting type for [Viewports]:
Undone | Cancels selection of previous layer to be frozen. |
Command prompts when layers are frozen:
Select an object on the layer to be frozen or [?/Settings]: | Select objects of the layers which is needed to be frozen. |
Select an object on the layer to be frozen or [?/Settings/Undone]: | Select Undone option to cancel freezing the previous layer. |
Select an object on the layer to be frozen or [?/Settings/Undone]: | Press ENTER or ESC to finish the command. |
NOTE: Command prompts are shown for Freeze option of Viewports parameter.
Command prompts when layers are frozen in a current viewport
Select an object on the layer to be frozen or [?/Settings]: | Select Settings option |
Enter setting type for [Viewports]: | Select Viewports option. |
In paper space viewport use [Freeze/Vpfreeze] : | Select Vpfreeze option. |
Select an object on the layer to be frozen or [?/Settings]: | In a viewport select objects of the layers which should be frozen. |
Select an object on the layer to be frozen or [?/Settings/Undone]: | Select Undone option to cancel freezing the previous layer |
Command prompts when freezing layers in the block selection:
Select an object on the layer to be frozen or [?/Settings]: | Select the Settings option. |
Enter setting type for [Viewports/Block selection]: | Select the Block selection option |
Enter block selection nesting level [Block/Entity/None/] | Select the option for the nesting level. |
Select an object on the layer to be frozen or [?/Settings]: | Specify in the drawing the objects of the layers to be frozen. |
Select an object on the layer to be frozen or [?/Settings/Undone]: | Press ENTER or ESC to complete the command. |
Info: NanoCAD is a user friendly, inexpensive, and yet powerful, CAD platform for personal computer, that allows a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware supports groundbreaking, collaborative and customizable features to enhance your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
