The FEdit Command
Icon: Edit
Command line: FEDIT
The command allows you to edit nanoCAD’s objects such as tables, notes, dimensions, singleline and multiline text.
The command opens following dialogs for editing:
- a table, a note, a dimension, a singleline and a multiline text (the Text settings dialog window) – if Yes is chosen for the Program objects, Dimensions, Regular text and Multi-texts options of the Settings nanoCAD Int dialog box on the Main options tab of the By double-click section (the Tools menu –Advanced Settings),
- a table, a note, a dimension – if No is chosen for the Program objects and Dimensions options of the Settings nanoCAD Int dialog box on the Main options tab of the By double-click section.
For more information, see the corresponding sections of this guide.
Info: NanoCAD is an easy-to-use, inexpensive, and yet powerful, CAD app for Windows, that provides an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware ensures progressive, collaborative and customizable features to raise your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
