Settings of raster snap
Menu: Tools – Drafting Settings > Object snap tab > button
Status bar: context menu of > Setup raster snap
Command line: R2VSNAPSETUP
Raster snap have to be setup to help program to recognize types of raster objects (lines, arcs, circles) correctly.
Snap operations are based on recognizing algorithms for raster objects. The program calculates a vector object, ideally approximating raster lines, which are close to mouse pickbox and offers to snap to characteristic points of the object. The efficiency of raster snap highly depends on parameters, specified in the Raster Snap Settings.
To specify settings for a raster snap:
1. Open Raster Snap dialog from context menu or by button near Raster on Object Snap tab from Drafting Settings dialog.
2. Set raster snap settings in accordance with your raster image characteristics:
Settings:
Min Length: This parameter defines the minimum size of a raster object that can be recognized.
To set Min Length:
- Click button and specify distance (2 points on raster line) that should be recognized as line.
or - Enter value to the field.
Max Width: This parameter defines the maximum width of raster lines that can be approximated by lines, arcs, circles, and polylines. If the width of a raster line exceeds Max Width value, then the only possible recognition mode is Auto tracing and approximating with an outline object.
To set Max Width:
- Click button and specify by 2 points maximum width of raster.
It’s better to set this value a little more than maximum width of the thickest line in the image.
Max Break: Sets the length of the maximum ignored breaking raster lines. If a raster line is broken into parts it should be traced as an entire object, then the value of Max Break should be set to the largest gap between the raster line parts. The program will ignore the breaks and create single vector object, approximating the whole raster line. By setting a comparatively large value of the parameter, users can, for example, trace dash-dotted raster lines, and arcs as single entities.
To set Max Break:
- Click button and specify by 2 points the largest gap between the raster line parts.
Accuracy This parameter determines the accuracy of approximation of the original raster object with a vector one. If the original image is distorted (for example, circles have the form of ellipses), then reduce the value of the Approximation Accuracy parameter. However, this leads to inaccuracies in recognition, for example the program might take a short arc for a line. When the quality of a raster image is high, increase the value of the Approximation Accuracy parameter. Sometimes before tracing the quality of the raster image can be improved by application of a smoothing filter.
To set Approximation Accuracy:
• Move slider.
3. When ready – click OK button.
Info: NanoCAD is a simple, cheap, and yet powerful, CAD freeware tool for PC, that provides a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware ensures creative, collaborative and customizable features to raise your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
