Point Cloud Vertical Section
Ribbon: Point Clouds – Clip and Section – Section > Vertical Section
Menu: Point Clouds – Section > Cut
Toolbar: Point Clouds > Vertical Section
Command line: NPC_SECT_CUT
Vertical section is similar to vertical section in Right, Left, Front, Back view or the result view of vertical section. Section plane is perpendicular to the current view plane.
Vertical section performed by 2 points. First point determines vertical plane for section. Second point determines the section depth.
Create cut section:
- Set Right, Left, Front, Back view or the result view of vertical section. Section plane is perpendicular to the current view plane.
- Run command.
- Specify cut position in section view.
- Specify section depth. This point determines the observer position in result view.
- Select required view to display the section.
Info: NanoCAD is a simple, cheap, and yet powerful, CAD app for Windows, that allows a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our software provides groundbreaking, collaborative and customizable features to enhance your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
