Extend Vectors
Ribbon: Home, Draw – Modify > Break at Point
Menu: Modify – Break vectors at point
Toolbar: Modify –
Command line: VCBREAKATPOINTCMD
The Extend command extends vector objects to their real or imaginary crossing with other objects, called boundaries or boundary edges. Extended objects are selected by specifying an extended part.
When several boundaries are specified, the object is extended to the nearest one. The object can be selected again to extend it to the next boundary edge.
If you press ENTER in the command prompt Select objects or [?]:, all existing objects are transformed into boundary edges. When you select object to be lengthen, nearest objects are selected as boundary edges.
You can cut objects without closing the command. Press SHIFT. when you are selecting objects.
Fence Selection of objects by a crossing line which can consist of several segments.
Crossing Selection of objects with a crossing frame.
Project Mode of extending objects by intersection of their projections with the boundary in 3D space.
The option opens the prompt in the command line:
Enter a projection option [None/Ucs/View/] :
None Only objects that are crossed by the specified boundary in 3D space are selected
Ucs Defines the projections of objects in the XY plane of the current UCS and cuts objects which are not intersected by the boundary in 3D space.
View Defines the projections of objects in the direction of the specified view and cuts objects which are not intersected by the edge.
Edge Specifies the extending mode of objects by imaginary extension of the edge.
Enter an implied edge extension mode [No extend/Extend] :
No extend Switches off the cutting of objects by imaginary extension of the edge.
Extend Switches on the cutting of objects by imaginary extension of the edge.
Delete Deletes selected objects.
Back Cancels the last change executed during performance of the command.
Selection of edge | Selection of object with pickbox | Selection of objects with crossing frame | Result |
Select objects or [?]: Select the object that is to be used as the edge.
Select objects or [?]: Select next object or press ENTER to start selecting objects to extend.
Select object to extend or [?/Fence/Crossing/Project/Edge/Delete/Back]: Select an object.
Select object to extend or [?/Fence/Crossing/Project/Edge/Delete/Back]: Select Crossing and select other objects. Press ENTER to finish the command.
