Save a Layout as a template
Ribbon: Layout – Layouts > Save Layout as Template
Menu: Insert – Layout > Save Layout as…
Layouts Manager dialog: Save layout as template
Command line: LAYOUTTOTEMPLATE
This command saves the created layout as a template with a *.dwt, *.dwg or *.dxf extension.
The command prompts, by default, to save the last active layout:
Enter layout to save :
Press ENTER to confirm. Enter the name in the command line and press ENTER to save a different layout.
The command opens the Save Document File dialog box:
To save a template in the Save Document File dialog box:
1. Specify the path from the drop-down Save in list;
2. Enter a name into the File name field;
3. Select the Drawing Template (*.dwt) format from the drop-down Save as type list;
4. Click Save
Info: NanoCAD is an easy-to-use, low cost, and yet professional, CAD freeware tool for PC, that allows an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our program supports creative, collaborative and customizable features to raise your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
