Modes and options of attribute definitions can be modified of the mode of editing a block definition:
- Open the Block Editor (menu Tools – Block editor), select the block, click OK.
- In the mode of editing a block definition, select the attribute.
- Set the required attribute modes and options on the Properties panel.
Left double-click on the attribute opens the Attribute Redefinition dialog box, were it is possible to modify Tag, Prompt and By default attribute value.
