Trim Vectors
Ribbon: Draw – Modify > Smart Trim
Menu: Modify – Smart trim
Toolbar: Modify –
Command line: SMARTTRIM
The Smart trim command differs from the Trim vectors in automatically selecting all vector objects in the document as potential cutting edges. Selected objects are cut to the nearest cutting edges.
? | Opens the additional options to select objects. |
Fence | Selection of objects by a crossing line which can consist of several segments. |
Crossing | Selection of objects with a crossing frame. |
Project | Mode of cutting objects by intersection of their projections with the boundary in 3D space. The option opens the prompt in the command line: Enter a projection option [None/Ucs/View/] :
Edge | specifies the cutting mode of objects by imaginary extension of the edge. The option opens the prompt in the command line: Enter an implied edge extension mode [No extend/ Extend] :
eRase | Deletes the selected objects. |
Back | Cancels the last change executed during performance of the command. |
Select objects or [?]: | Select the object that is to be used as the edge. |
Select objects or [?]: | Select next object or press ENTER to start selecting objects to extend.. |
Select objects to erase or [?]: | Select objects and press ENTER to delete them. |
Select object to extend or [?/Fence/Crossing/Project/Edge/Delete/Back]: |
Select an object. |
Select Crossing and select other objects. Press ENTER to finish the command. |
