Ribbon: Raster – Settings > Separate raster
Menu: Raster – Separate raster
Toolbar: Raster – Separate raster
Command line: SEPARATERASTER
You can separate raster images from original reference and assign new name and path, if raster image was inserted to drawing more than once or its copies were created in a session.
1. Run command Separate raster.
2. Select raster images to create separate references to files.
3. Press Enter.
Separated raster images marked in External references dialog by adding _clone_N to the name, N – ordinal number of copy, and by status – Not Found.
You can give new name and path for raster image if click the Save button.
If separate raster images are not saved, then program prompts you to save them on exit.
Info: NanoCAD is a user friendly, affordable, and yet powerful, CAD software tool for personal computer, that allows an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our tool supports progressive, collaborative and customizable features to boost your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
