Linear aligned note
Ribbon: Home, Annotate – Leaders > Linear Aligned note
Menu: Draw – Notes > Linear aligned note…
Toolbar: Utilities –
Command line: LINM
This command opens the Linear aligned note dialog box to set the note options:
By left edge. | |
By centre. | |
By right edge. |
Other icons:
The Select line icon is used to override the insertion place of the extension line. The icon is available when you edit the marks of linear constructions inserted into the drawing. | |
The Auto repeat icon allows you to mark several linear constructions without a repeated command call. For each new leader, the Linear constructions marking dialog box will open to set new options for the leader, for example, new text. | |
The Multiple insert icon allows you to mark several linear constructions without a repeated command call. All leaders are drawn with same options and with the same text. |
To create a linear aligned note:
- Select the required note options.
- Click OK.
- Select line of construction, on which the mark will be located.
- Specify the text position.
Info: NanoCAD is a simple, low cost, and yet powerful, CAD application for PC, that provides an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our program ensures innovative, collaborative and customizable features to enhance your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
