Create a viewport by object
Ribbon: Layout – Layout Viewports > Add Viewport by Object
Menu: View – ViewPorts > by Objects
Menu: Insert – ViewPorts in Layout > By Objects
Toolbar: Layout –
Command line: DDOBJECTVIEWPORT
This command allows you to convert a closed polyline, circle or ellipse into a viewport.
nanoCAD allows use of this command on the current layout tab in which the viewport should be located, as well as directly from the model space.
Create a viewport by object from the model space
? | Calls additional options to select the objects. |
Extent | Display all objects from the model space in the viewport. |
Active<0.000831> | Display the current view of the model space in the viewport. |
Paper<1.000000> | Set the viewport scale corresponding to the layout scale. |
When you start the command, the Select Layout dialog box opens. Select the layout on which you want to place the viewport.
By default, you will be offered the layout that was current (active) before the command start.
Select closed object to create viewport or [?]: | Select the closed object. |
Input or choose view scale or [Extents/Active<0.000831>/Paper<1.000000>]: | Input scale of the viewport or select necessary option. |
Create a viewport by object from a layout
Info: NanoCAD is a simple, affordable, and yet professional, CAD platform for personal computer, that allows a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our tool ensures progressive, collaborative and customizable features to raise your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, if you like it.
