Ribbon: Home- Modify> Delete duplicates
Manu: Modify– Delete duplicates
Toolbar: Modify Object –
Command line: DELETEDUPLICATES, OVERKILL
The command is intended for deleting repeating or overlapping objects: points of lines, arcs, circles and polylines.
In the process of the command work, the geometry of the selected objects is compared, duplicate elements are deleted.
- Run the Delete duplicates command.
- Select objects in the drawing.
- Configure object comparison parameters in the dialogue box that appears.
Tolerance: Sets the precision with which numeric comparisons of object parameters is made. If this value is 0, the objects being compared must match completely for the command fulfillment.
Ignore object property:: Selects object properties to ignore during comparison.
- Click OK.
- Select an action in the command line:
Delete duplicates? [All/Current/Skip] :
All | Delete all found duplicates. |
Current | Delete the selected object. |
Skip | Move to the next object without deleting the selected one. |
Info: NanoCAD is an easy-to-use, cheap, and yet powerful, CAD freeware tool for personal computer, that allows an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our tool supports creative, collaborative and customizable features to boost your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and purchase later, in case you like it.
