Node note
Ribbon: Home, Annotate – Leaders > Node note
Menu: Draw – Notes > Node notes …
Toolbar: Utilities –
Command line: NLD, NLEADER, NOTEK
This command opens the Node note dialog box to set the note options:
By left edge. | |
By center. | |
By right edge. |
Other icons and options:
Inclination step of extension lines: | Drop-down list to select the inclination. In the list the following inclinations are available:
To create a node note:
- Select the required note options.
- Specify the oval/circle center.
- Specify the oval/circle size.
- Specify the shelf position and/or the leader pitch angle.
Info: NanoCAD is a user friendly, affordable, and yet professional, CAD application for personal computer, that allows a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our program ensures groundbreaking, collaborative and customizable features to boost your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
