Point Clouds Display Setting
Display boundary
Ribbon: Point Clouds – Settings > Switch point cloud boundary
Menu: Point Clouds – Settings > Display point cloud boundary
Command line: SWITCHPCBOUNDARY
Enable/disable boundary box of each point cloud in the drawing. Disable by default.
Display all points
Ribbon: Point Clouds – Settings > Switch point cloud display tree
Menu: Point Clouds – Settings > Display all points
Command line: SWITCHPCDISPLAYTREE
Turn on / off the display of all points in the cloud. Disabled by default, so the number of points displayed on the screen depends on the performance of the PC’s graphics system.
Enabling this mode only affects the speed of displaying clouds and navigation in the workspace. This mode does not affect the speed of clouds processing by commands of stitching (registration), classification, etc. To speed up cloud processing operations, make it sparse with the Thinning the Point Cloud command, which reduces not the displayed, but the actual number of points in cloud. It is also possible to reduce the number of cloud points that get into the document during the import operation by checking the Spacing box and specifying the sequence number of imported points.
Zoom Extents after Import
Ribbon: Point Clouds – Settings > Switch point cloud import zoom extents
Menu: Point Clouds – Settings > Zoom extents after import
Command line: SWITCHPCIMPORTZOOMEXTENTS
Auto zoom extents mode to the point cloud after import.
In the majority of cases after importing it is required to zoom to the point cloud. This mode does this automatically. The mode is enabled by default.
Ribbon: Point Clouds – Settings > Snap Point Cloud
Menu: Point Cloud – Settings > Snap Point Cloud
Command line: SWITCHPCSNAPON
Snap to separate points in Node object snap mode. The mode is enabled by default.
Snap to Geometry
Ribbon: Point Clouds – Settings > Snap to Edges and Nodes
Menu: Point cloud – Settings > Snap to Edges and Nodes
Allows you to snap to fit points of geometry, recognized in the cloud by features recognition commands.
By default, the mode is on.
Info: NanoCAD is a user friendly, low cost, and yet professional, CAD freeware tool for PC, that allows a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our software provides groundbreaking, collaborative and customizable features to raise your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and buy later, if you like it.
