Sheet sets
You can create a sheet set that is a specific folder containing arranged layouts (sheets) and named views from the current project drawings. Sheet set permits to plot all included sheets even from different drawing files. Alternate names for sheet set in other systems are folder, album, collection should use the Sheet Set Manager functional bar to work with a sheet sets.
Sheet set data are saved in .dst file. There are two types of sheet sets: set of layouts (includes drawing layouts) and set of views (includes model named views).
NOTE: Including layout or view into a sheet set does not change their real position, they stay at the same places as before.
ATTENTION! It is not recommended to include the same layout into different sheet sets (you should better create another file with an xref to the main one).
