The Forms tab
The Forms tab is designed to set parameters of text parts of tools to create standard drawing elements.
Table
Setting display parameters of nanoCAD tables.
Layer
Specifies the layer on which the inserted (created) table will be located by default.
Color
Sets the color for table elements.
Line thickness
Assigns thickness to border lines of table cells.
Text style
Sets the standard text style inside the table.
Text height
Allows you to set a standard value for the text height. You can select the height from a set of standard values according to GOST 2.304 or enter your own height value manually.
Text color
Controls the choice of text color in tables. You can choose a color from a standard set of values or set your own color from the built-in palette.
Text weight
Allows you to select the line thickness of text characters in the table. The By layer value corresponds to the standard thickness for the layer on which the tables are located by default. The By block value corresponds to the standard thickness for the block that contains the table. Selecting the By object value sets the thickness specified for table objects manually.
The Default value corresponds to the default line thickness for this drawing.
Text indent
Allows you to select the value of the text indentation from the cell borders.
Notebook
Notebook path
The path to the notebook file.
Info: NanoCAD is a user friendly, affordable, and yet powerful, CAD platform for PC, that delivers a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our program ensures creative, collaborative and customizable features to enhance your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
