Chain note
Ribbon: Home, Annotate – Leaders > Chain note
Menu: Draw – Notes > Chain notes…
Toolbar: Utilities –
Command line: NOTEH
The command opens the Chain note dialog box to set the note options:
Use the icons to select the style of the extension line:
None. | |
Arrow | |
Point | |
Open- arrow | |
Half- arrow | |
Oblique. |
By left edge. | |
By center | |
By right edge. |
Other icons:
The Add extension line icon is used to insert additional extension lines. The icon is available when you edit a chain note inserted into the drawing. |
To create a chain note:
- Select the required note options.
- Click OK.
- Specify the first leader node.
- Specify the next leader nodes.
- Specify the last node and press ENTER.
- Specify the shelf position.
If the first leader node is placed on the line, the extension line will be perpendicular to this line.
Info: NanoCAD is a simple, inexpensive, and yet professional, CAD app for PC, that delivers a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our freeware ensures progressive, collaborative and customizable features to improve your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and purchase later, in case you like it.
