Pixel drawing
Tools for pixel drawing used for drawing and erasing rater data of an image.
To draw on raster image:
Ribbon: Raster – Draw > Pencil
Menu: Raster – Pencil
Toolbar: Raster –
Command line: PENCIL
Color Setting the color of the pencil. The option opens the Select Color dialog box. The option is available only if the drawing contains color raster images. On monochrome images, the raster line will be displayed in the main color. On grayscale images – by one of the shades of gray that most closely matches the selected color in terms of brightness. On color images – by the selected color.
Current color or [Color]: Shows current color and an option to change it.
Draw or input pencil width <1.00000>: Shows current width of a line. Can be changed with user input.
Draw curve on raster or “Enter” to finish: Draw a line.
To erase on raster image:
Ribbon: Raster – Draw > Eraser
Menu: Raster – Eraser
Toolbar: Raster –
Command line:RASTERERASER
Color Setting the color of the eraser. The option opens the Select Color dialog box. The option is available only if the drawing contains color raster images. On monochrome images, the raster line will be displayed in the main color. On grayscale images – by one of the shades of gray that most closely matches the selected color in terms of brightness. On color images – by the selected color.
Draw or input eraser width <1.00000>: Shows current width of a line. Can be changed with user input.
Info: NanoCAD is a simple, cheap, and yet powerful, CAD platform for PC, that provides an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our software supports creative, collaborative and customizable features to boost your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and purchase later, in case you like it.
