Sheet set custom properties
You can add custom properties for sheet set. Each custom property is associated with sheet, sheet subset or sheet set. Custom property values are displayed only with the owner sheet set and they can be used in the text fields.
Click the Edit Custom Properties button to add custom properties in the Sheet Set Properties window or in the Sheet Subset Properties. The Custom Properties dialog appears.
Add new custom properties (with Add…) or remove existing properties (with Delete).
Click the Add… button to open the Add Custom Property dialog. Enter new property name, default value (this value is added for the first time) and use radio buttons to choose the owner of the custom property: sheet set, sheet or sheet subset.
Additional property will be displayed in the Custom Properties dialog.
The Sheet Set Properties dialog shows custom properties in the special tabs depending upon the owner (sheet set, sheet subset or sheet).
Sheet Set Custom Properties, Sheet Custom Properties and Sheet Subset Custom Properties contain the custom properties that are associated with the sheet set, sheet and subset.
It is possible to edit values of properties in the Sheet Set Properties dialog.
Edit main and custom properties of sheet and subset in the Sheet Properties and Subset Properties dialogs opened with the Properties context menu. Similar properties of a specific sheet can be changed in the Sheet Properties dialog from the context menu Properties.
Info: NanoCAD is a user friendly, inexpensive, and yet professional, CAD application for personal computer, that provides a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our freeware ensures innovative, collaborative and customizable features to improve your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and buy later, if you like it.
