ScriptMaster
CAD drafting MechWizard 0Main menu: Construction – Library objects – MechWizard – CAD software MechWizard 1ScriptMaster.
CAD drawing MechWizard 2Ribbon: Construction – MechWizard – CAD drafting MechWizard 3ScriptMaster.
CAD software MechWizard 4Toolbar: MechWizard – CAD drawing MechWizard 5ScriptMaster.
CAD drafting MechWizard 6Library: Context menu command “Open with ScriptMaster” on any element library.
CAD software MechWizard 7Command line: SPSMASTER.
The command opens “ScriptMaster” for creating and editing a database object.
Dialog
The title of the current element is indicated in the headers of the “ScriptMaster” dialog. An “*” signifies that unsaved changes were made to the item.
CAD drawing MechWizard 8
1. Main menu. Contains all commands for creating and editing objects and scripts. Contains sections:
· Object · Edit · Script · Master2. Toolbar. Contains basic commands for creating and editing objects.
· CAD drafting MechWizard 9“New object”. The command opens a dialog for creating a new base element. · CAD software MechWizard 10“Open”. The command is designed to select another element from the base. · CAD drawing MechWizard 11“Save”. The command saves changes to the current object. · CAD drafting MechWizard 12“Undo”. The command cancels the previous action. · CAD software MechWizard 13“Redo”. The command redo the last undone action.3. Object tree. In the object tree, you can navigate through the object properties and manage them through the context menu.
4. Workspace. The script and table, as well as other properties of the object are edited in the work area.
5. Notification area. The results of the script check and search / replacement are displayed in the notification area.
6. Status bar. The status bar displays the current state of work with the object:
· Setting the path to the current database; · Current cursor position; · Edit state – insert or replace; · Script sign for reading or editing.The menu bar
Object
Menu item object allows it to work with database objects in nanoCAD Construction 23:
CAD drawing MechWizard 14
Object – creates a new element base (By pressing keys Ctrl+N or clicking on the icon CAD drafting MechWizard 15 Create on the toolbar).
After issuing this command, a dialog box appears to New object
CAD software MechWizard 16
To create a new object, you must specify:
Folder in which to save the new object
Name (will be displayed in the browser)
Comment (will be displayed in the tooltip)
Select a way to create a new object
CAD drawing MechWizard 17
Create an empty object – creates a table and designs without having one script selected from the template.
Default template – empty script.
Create as copy of prototype – creates an object by copying the entire prototype object (along with the script, tables, performances and three-dimensional models.
CAD drafting MechWizard 18
Use the button CAD software MechWizard 19 to select an object to create a prototype object.
Open – Open an existing part (keyboard shortcut Ctrl+O or icon CAD drawing MechWizard 20Open on the toolbar).
After selecting the command, a dialog box appears Select the details allowing you to select or find the item in the current database in Construction Site 4.
CAD drafting MechWizard 21
Save – save changes to the current member base (keyboard shortcut Ctrl+S or icon CAD software MechWizard 22 Save on the toolbar).
Set object preview – allows you to set as a preview for the object in the browser database objects nanoCAD.
Exit – close Master objects
In paragraph object available list of recently used items.
Editing
Menu item Edit allows you to work with the current database nanoCAD Construction 23:
CAD drawing MechWizard 23
Undo – cancel the last action (promptness pressing keys Ctrl+Z or clicking on the icon CAD drafting MechWizard 24Undo on the toolbar).
Redo – undo the last action (promptness pressing keys Ctrl+Y or clicking on the icon CAD software MechWizard 25Repeat on the toolbar).
Find – search for a given string on the script of the current element (promptness keys Ctrl+F).
Calling this command opens a dialog box Find
CAD drawing MechWizard 26
Looking provided an opportunity to take into account only whole words and case search string using by appropriate switches.
Also have the opportunity to select the search direction.
Go to the next matched string by pressing find Next.
After you click Cancel , you return to the previous menu.
Speas dropdown input field allows you to select the last used values.
Replace – search for a given string with a new one.
After calling this command, a dialog box appears Replace
CAD drafting MechWizard 27
When replacing provides an opportunity to consider only whole words and case search string using by appropriate switches. It is also possible to carry out replacement in the selected area or throughout the text.
Daylight without replacing the matched string to the next by pressing find Next.
When you click Replace matched string is replaced by a new one at the current position.
After you click Replace All all found strings will be replaced.
Button to return to the previous menu, press Cancel.
Go to – command allows you to go to a specific line (promptness keys Ctrl+G).
CAD software MechWizard 28
Find and replace on the database – allows you to search and replace strings in the base.
CAD drawing MechWizard 29
There are opportunities to search the entire database or in a folder, the search is case sensitive, whole words, as well as multi-line test, the search for the script, table, table name resources and facilities (Use advanced options )
Script
Menu script allows you to work with the current script object database nanoCAD Construction 23:
CAD drafting MechWizard 30
Get script from other object – command allows you to copy the script from another object.
Set script to all objects in selected folder – script command sets the current object to all objects in the selected folder database elements nanoCAD Construction 23.
Show script of other object – you can view the script of another object without changing it.
Insert script template – command allows you to take in the script as the current object previously saved template.
Save script as template – allows you to save the current script object as a template for future use.
Show localized script – command allows you to view localized script based on the data of the resource table.
Script Master
In general, writing the script for the majority of standard parts is not required. Just open the script details, like on purpose, and copy it. However, it must be remembered that the parameters in the model (figure) must strictly match the prototype.
nanoCAD Construction 23 is a convenient mechanism for self-compilation step algorithms that control the behavior of the items in the time of insertion and editing object – Master browser.
Call Master browser via the menu item Master / Script wizard
· General properties · Parameter Properties · Calculation parameter · Drawing Conditions · working planes · show / Hide parameters · Display conditions · Check boxes · Current scriptAt any step of the script wizard may move buttons << Back and Next >> .
Button Cancel exits the wizard.
Basic properties
CAD software MechWizard 31
Object description (Property Description). This parameter is optional, it describes the common name of the object. For example, nut, bolt, etc.
Object type (type). This parameter is required, it is advisable to fill it in Latin characters. Serves to identify the object as belonging to a group. For example, StdArborParts – standard parts shaft, StdJointParts – fastenings.
Object Name (Name of facility). This parameter is required, it is advisable to fill it in Latin characters. Defines elements within the group, given strTheType. For example, a screw bolt – Screw, for nuts – Nut, for washers – Washer etc.
Object subtype (subtype). Additional parameter, it is desirable to fill it in Latin characters. Defines a specific subtype of GOST. For example, if the name of the object – Nut (Nut), then simple nuts subtype is Simple, from crown – Castle etc.
These parameters set by the user, based on its project object interaction, and can be arbitrary. Hard list is not, and they can be changed at any time. They will only be used in scripts to automatically establish dependencies (details – in the description of scripts).
Specification. Description line items for transmission specification.
CAD drawing MechWizard 32
Not used
All parameters specified in the table, are automatically available for operations over them from the program during the insert or edit the object. If a variable is used only in the process of creating a graphic image, then use it in the script is not necessary.
Protected (used internally)
If necessary, display the parameter dialog during insertion.
Public (visible)
Used to transfer parameters during insertion and editing of other objects.
Changeable (available for editing)
Available to change other objects in the editing process. Variable of the property, will pick up from the table and the necessary parameters on the basis of the obtained values to reconstruct the details of the model.
Calculation of parameters
CAD drafting MechWizard 33
Set parameter in the dialogue
Variable for which this flag is set to be available for editing of dialogue insert details.
Dynamic selection
Processed when the position of the cursor relative to the insertion point of the object according to the formulas in the designated parameter value in the range of “minimum value” – “Maximum”.
Calculate after dialouge is shown using dynamic selection by expression
Calculated after the call dialogue and visual selection as expression in the Parameter Value.
Dont calculate parameter
Defines the minimum value. Can be expressed as a function of other parameters. Determination of the value of the parameter as a function of the cursor or other parameters. Available functions may be called from the context menu or manually entered into the appropriate input box.
Minimum value
CAD software MechWizard 34
Context menu is available in the input field.
Maximum
Defines the maximum value. Can be expressed as a function of other parameters. Context menu is available in the input field.
Conditions rendering
Add a line in the drawing model, rendering which we will operate from the dialog during the insertion of parts (for example, they will be highlighted Magenta). Pressing the button CAD drawing MechWizard 35 will open a dialog box object properties and assign as a condition of their appearance in the drawing text parameter. In this case SLICE.
CAD drafting MechWizard 36
Size “S”, necessary for proper recognition, automatically appears in the parameter list, but you must enter a parameter draw.
CAD software MechWizard 37
Fragment dialog box Properties settings
CAD drawing MechWizard 38
In the name field switch is set “Cut”. The parameter rendering paste from the context menu variable “SLICE”.
After the completion of the script retain the item and exit the editor. Of the database tree select our item and insert it into the model. In the editing dialog parts we have a switch incision through which we can control the rendering of relevant lines.
CAD drafting MechWizard 39
Working planes
Workplanes determine the position of the items in the time of insertion and editing. Determination of working planes dialog box to the work plane.
CAD software MechWizard 40
CAD drawing MechWizard 41CAD drafting MechWizard 42Creating a plane parallel to the plane OYZ
CAD software MechWizard 43CAD drawing MechWizard 44Creating a plane parallel to the plane OXZ
CAD drafting MechWizard 45CAD software MechWizard 46Creating a plane parallel to the plane OXY
Show / Hide parameters
In this step, you must identify the available options in the menu items. The selection is made by setting a checkmark APPLICABLE parameter
CAD drawing MechWizard 47
Display conditions
In this step, display conditions defined species . The selection is made by setting a checkmark APPLICABLE parameter and determining the conditions of his hiding
CAD drafting MechWizard 48
Check boxes
In this step, there are the following settings:
· Show dialogue before object is inserted · Show object while inserting · Regenerate object suppression contour after insertingCAD software MechWizard 49
Current script
In this step, you can view and edit the resulting script. Clicking on the button Save and OK to apply the current script items
CAD drawing MechWizard 50
This is the final step.
Master dependencies
Creating dependencies for interaction with other items going online.
Call Master dependencies via menu Master / Master Dependency .
Further, following the screen prompts on the command line, place the drawing model details and select the items with which it must interact.
After placing the parts in the drawing, a dialog box Managing Dependencies. Functionally, the dialog box is divided into two parts bookmarks. Bookmark this Parametric dependence and Assembly constraints.
CAD drafting MechWizard 51
Definition of parametric relationships occurs directly in the dialog box. It’s enough to double-click on the option to specify the details of the child (it will automatically appear in the left-hand side) and bring it into line with the parameter of the parent object. In the right-hand side can be used mathematical expressions.
CAD software MechWizard 52
Types of assembly and parametric relationships are defined in the dialog box. Parameters can serve as table settings objects and definable expression.
CAD drawing MechWizard 53Axial and surface alignment
CAD drafting MechWizard 54Surface alignment
CAD software MechWizard 55Axial alignment
CAD drawing MechWizard 56Direction
CAD drafting MechWizard 57Sets the direction for the dependencies (Counter directional / Co-directional)
Once all the dependencies are installed, you can click OK, successively pass through the dialog boxes and set the options you want.
Eventually, an automatically generated string specifications necessary to automatically detect dependencies.
CAD software MechWizard 58
Formation data for transmission to the specification can be done in automatic and semi-automatic modes. Some information can be inserted on the basis of the table of parameters associated with the geometry of the figure, the part can be entered manually in the editing dialog standard parts.
Call Master BOM line via menu Master / Master BOM line .
CAD drawing MechWizard 59
In the drop-down list are tabulated parameters involved in drawing details.
CAD drafting MechWizard 60
For a complete description of information on standard parts must be able to adjust or supplement information. For example, cover screws or the class thread. In this case, just add a “#”.
The editor position will be able to insert text between the two lattices, and then save.
CAD software MechWizard 61
Object tree
CAD drawing MechWizard 62
Tree object contains the following sections:
· Description ; · Parameters; · Methods; · Function; · Forms; · Resources table; · Script .If the open file has been modified, its wood properties can be irrelevant. To actualize the properties tree to choose the context menu to update the object tree.
Description
When you click on the section Description of the workspace displays the following properties.
CAD drafting MechWizard 63
Property name – the name of the object to be displayed in the browser database.
Comment is displayed in the tooltip to the object.
Standard product allows you to set the standard (GOST, DIN, ISO, etc.).
Part list entry, is usually not be filled in the properties, and the variable defined in a script.
You can also put a tick:
Object have 3D view.
Cutting in detail
Object for 3D only.
In addition, the properties of the unique identifier for the object.
Parameters
Section Parameters contains three subsections:
· public, · protected, · tabular.CAD software MechWizard 64
The public section Upcoming shows a table of open (public) parameters along with their comments.
CAD drawing MechWizard 65
Furthermore, the parameters are displayed in a tree branch.
CAD drafting MechWizard 66
Section Protected contains a list of protected (protected) parameters, which are also displayed in a table and drop-down list of branches in the tree object.
CAD software MechWizard 67
Section Table includes a list of tables detail
CAD drawing MechWizard 68
Table and column of the table in the current workspace synchronized depending on the position of the cursor in the object tree. Tables in the object may be a few, while the identification is made on behalf of the table. Popup menu when the cursor position on the table includes the following tools:
CAD drafting MechWizard 69
When you select table name as a prefix to the parameters of an appeal to the names of variables are prefixed with the table name. For example,Table0.dr.
You can add / delete rows from a table and add a parameter to a table.
There is also exported to Excel, text format and import from them.
Whenever the context menu on a separate parameter tables are available options remove a single parameter and set the type (Valid (Real), String (String) or a (Integer).
CAD software MechWizard 70
To rename a table parameter, select it and click on his name left mouse button, or press F2. If the parameter name has changed, it will automatically run search and replace in the script to a new name parameter correctly processed by the script.
Methods
Section Methods includes event handlers and custom functions.
CAD drawing MechWizard 71
When selecting a specific function in the script is its description (synchronized current line).
Red light CAD drafting MechWizard 72 icon in the function indicates the presence of a function in the script is present, CAD software MechWizard 73 white – about lack. When you double clicking on the corresponding function in the script created by its pattern.
Implementation
Section Versions list includes 2D and 3D versions
When selecting the root partition versions are all the performance, and the choice of a particular (for example, Version 1) – displays the filtered views of this execution. To create a two-dimensional view of a new version should be specified in the context menu Add performance – automatically create 2D views.
To create this kind of performance you need to select the required performance and the shortcut menu – Add 2D view.
· 2D view – parametric graphic nanoCAD · 3D view of the Construction Site 23 – script to create a solid model (opening section of the shaft, etc.)Deleted when you delete all kinds of performance of this version.
To set the parameters of the form, select it, and the right side of the workspace to set view orientation (Front, Left, Top , etc.) and the type of form ( cut, cut C, C size etc.).
CAD drawing MechWizard 74
In the context menu, you can select types of operations on this performance.
These options add \ remove kinds of current version:
CAD drafting MechWizard 75
The following context menu options are designed to work with the selected view of the current execution.
CAD software MechWizard 76
Recognize view – parametric recognition graphics nanoCAD.
Nonparametric recognize view – simple nonparametric reference charts, graphics taken from the object as it is.
Edit view as text – description of species opens in a text editor.
Set preview from objects – objects selection nanoCAD to create a preview of this species.
Import preview picture from file – creating thumbs on the basis of the previously saved file.
Export preview picture to file – Saves the preview in a file.
Form editor
Form Editor
Database objects nanoCAD Construction 23 supports the use of custom dialogs for inserting and editing. Creating such dialogues (forms) is made in Form Editor, which can be accessed from the dialog boxes Create Group, Create marker and Object Wizard .
Button CAD drawing MechWizard 77 Open the form editor.
File
· Test. Opens the form for viewing and testing. · Output. Closes the form editor.Correction
· Cancel. Cancels the previous execution of operations. · Cut, copy, paste CAD drafting MechWizard 78CAD software MechWizard 79CAD drawing MechWizard 80. Command working with the clipboard. · Select all. Selects all the controls on the panel shape. · Remove. Deletes the selected controls from the form. · Group. Group the selected controls. · Ungroup. Cancels the grouping selected controls.View
· By … edge. Alignment commands selected controls along one edge. · Align dimensions. Aligns the selected controls dimensions. · Above and below. Reverses the order of the tab selected control by moving it up a level or down · Forward, backward . Changes the tab order of the selected control by moving it to the first or the last level. · Tab order CAD drafting MechWizard 81. Includes display serial numbers tab controls. · To set the tab order to be pressed sequentially controls on the left mouse button. Tab order will be set according to the sequence control option. · Properties. Enables and disables the additional window Properties. · Variables. Enables and disables the additional window variables. · Grid CAD software MechWizard 82. Turns on and off the grid and snap to grid. · Indents CAD drawing MechWizard 83. Enables or disables the frame shapeInsert
There are commands insert controls
· CAD drafting MechWizard 84Input field .. · CAD software MechWizard 85Checkbox .. · CAD drawing MechWizard 86Switch. · CAD drafting MechWizard 87List. · CAD software MechWizard 88List from the database. · CAD drawing MechWizard 89Combo box. · CAD drafting MechWizard 90Combo box from the database . · CAD software MechWizard 91Text. · CAD drawing MechWizard 92Group. · CAD drafting MechWizard 93Figure. · CAD software MechWizard 94Panel. · CAD drawing MechWizard 95Button. · CAD drafting MechWizard 96Table with filtering. · CAD software MechWizard 97Table. · CAD drawing MechWizard 98Types and performance. · CAD drafting MechWizard 99Viewing.Forms panel
On the forms produced occupancy controls.
In the context menu of the forms are available editing commands: cut, copy, paste, group, ungroup.
To add a control to the form by one of the following ways:
· Select the desired control from the menu Insert or toolbar. Specify the insertion point and set the dimensions of the control panel on the form.After adding the control you want to bind it to a field in the Properties.
· In the open window, Variables , select the variable for which you want to add a control. Left-click on the variable in the list, and holding down the mouse button, move the cursor to the panel shape. Release the mouse button. Panel forms added group controls – text and input field .If you insert a control from the window variables hold down Control, then it is possible to select the type of control.
Selection of the control panel forms can be accomplished in several ways:
· Single click of the left mouse button. Selected one control. · Single click of the left mouse button while pressing Control . If the control is not selected, it is added to the current set. If a control is selected, it is removed from the current set. · Choosing a crossing . Click the left mouse button in the space bar form. Holding the button down and dragging a selection box set. Selected controls that are fully or partially captured by the selection frame.Editing the size of the control is done by using the “ grips “. When the grid is resized with a certain step.
Changing the position of the selected controls performed with the left mouse button on one of the selected items. When the grid movement occurs incrementally.
Align controls
In the menu View available commands align controls on edge and size.
Controls aligned to the left, and then by size .Grouping controls
Working with multiple controls may need to be fixing their relative position. If grouping is fixed relative position of the controls, and when you move one of the other grouped elements also move.
Select panel forms controls and issue the Group. Selected controls will be grouped.
Removing Controls made the command Delete.
Test the form
Before completing the form creation is recommended to execute the test to view the form.
Variables window
In the Variables are parameters of the object ( marker , database object , group ).
Icon CAD software MechWizard 100 marked parameters that are associated with controls editable form
Properties window
In the Properties lists the properties of the selected controls on the form. At the bottom there is a line prompt with a brief description of the selected property
The form and the design elements located on it interact with the script using properties and events.
Properties
All form properties start with a prefix “Form.”
Control properties (design elements) start with a prefix “Form.$$$”, where $$$ — name of the control on the properties panel of the form editor, case-sensitive.
Example:
Form.editbox.Value = “”;
When accessing the control value (design element), the “.Value” parameter can be skipped.
Example:
Form.editbox = “”;
For controls associated with script variables, the value can be passed through a variable.
Example:
// Bind the variable Form.editbox.Field = “strType”; //… OnDialogChanged { // The next three lines do same. // If values conflict, // priority is taken into account. // Priority decreases from top to bottom: Form.editbox.Value = “”; Form.editbox = “”; strType = “”; }
While the form is active, you can work with its properties and the properties of its controls as with ordinary variables. In this case, the changes made in the script will be applied to the form after exiting the reactor function.
function OnDialogChanged { if (Mode == 1) { Form.groupbox.Visible = FALSE; Form.Lable1.Left = 50; } else { Form.groupbox.Visible = TRUE; Form.Lable1.Left = 10; } Form.editbox.Left = Form.Label1.Left + 40; Form.Label1.Right = Form.Label1.Right + 38; }
Property
Access
Note
Form.Count
read
The number of controls on the form.
Form.Width
read
The width of the form’s client area.
Form.Height
read
The height of the form’s client area.
Form.Help
full
Link to the reference manual. If the path is relative, it is padded relative to the path to the project’s Help folder.
May be:
- the path to the chm-file with or without the chapter (don’t specify the protocol).
- link to file
- NormaCS page or document: http://help.spds.ru (Protocol is obligatory).
- help index
Form.$$$
full
The value of the control.
Form.$$$.Value
full
Form.$$$.Enabled
full
Control enabled/disabled.
Form.$$$.Visible
full
Control visible/invisible.
Form.$$$.Field
full
The name of the script variable associated with the control.
Form.$$$.Tooltip
full
Hint text.
Form.$$$.Left
full
Control size – indent on the left.
If a binding was set in the form editor, after changing the dimensions, the coordinates of all controls will be recalculated taking into account these changes.
Form.$$$.Top
full
Control size – indent from above.
Form.$$$.Right
full
Control size – indent on the right.
Form.$$$.Bottom
full
Control size – indent from below.
Form.$$$.Count
full
The number of items in the list or dropdown list.
Form.$$$.Items[#]
full
The #-th element of the list or dropdown list.
Eventы
An event handler in this context is a script function that is called in response to an event on the form. Events will be called form properties that store the names of event handlers. There are events of the form itself and events of its controls. You can work with them as with normal form properties.
Example:
//Assign the OnChange event to the OnEditChange function Form.editbox.OnChange = “OnEditChange”;
Event
When called
Form.OnShow
Before showing the form. All form properties are already defined.
Form.OnClose
Before closing the form.
Form.$$$.OnChange
After changing the value of the control by the user. Changing a control from a script does not generate this event.
Form.$$$.OnEnter
When the control receives input focus.
Form.$$$.OnLeave
When the control loses input focus.
Switches
The logic of the switches is somewhat different from other design elements. Multiple radio buttons are bound to the same script variable. Each of them is set to some value. The variable is set to the value of the enabled switch. The value is of type string. If “-1” is set, the value is assigned automatically, starting from 1, in TAB order. In this case, the value type will be numeric.
Radio buttons associated with a single variable are considered a group. Only one radio button can be enabled in a group. If the variable is not assigned, radio buttons located inside the same control are grouped. This is usually a Group or Panel.
Examples
Event handling. In the script code, bind the Edit control to the script variable d. When the Edit value changes, update the text in the Static label.
· Solution 1. When the EditBox value changes from the form, the OnDialogChanged function will be called. Assign EditBox control Field name = d. The EditBox control will automatically synchronize its value with the d variable.function OnDialogChanged { Form1.editbox1.Field = “d”; Form1.static1 = “Hole diameter: “ + d + “mm”; }
· Solution 2. Assign an OnChange event handler to the EditBox control.function OnDialogChanged { Form1.editbox1.OnChange = “OnEditChanged”; Form1.editbox1 = d; } function OnEditChanged { d = Form1.editbox1; Form1.static1 = “Hole diameter: “ + d + “mm”; }
· Solution 3. Let’s combine both previous solutions. The d variable will be synchronized with the EditBox control automatically, and the text of the Static label will be updated from the OnChange event handler.function OnDialogChanged { Form1.editbox1.OnChange = “OnEditChanged”; Form1.editbox1.Field = “d”; } function OnEditChanged { Form.Label = “Hole diameter:” + d + “mm”; }
List management. Build a list of values in a combo dropdown list.
function OnDialogChanged { // You can set the number after the values, but before the values – somehow clearer. Form.Combo.Count = 5; // Elements are numbered from 1. Form.Combo.Items1 = “(нет)”; Form.Combo.Items2 = “Item1”; Form.Combo.Items3 = “Item2”; Form.Combo.Items4 = “Item3”; Form.Combo.Items5 = “Item4”; // This command will fail because there are only 5 items in the list. Form.Combo.Items6 = “Item5”; }
Form properties
General
Help URL
Caption
Editor
Top margin
8
Height
400
Left margin
8
Bottom margin
8
Margin
CAD drawing MechWizard 101
Right margins
8
Grid
CAD drafting MechWizard 102
Grid step
8
Width
400
Note:
In the “Help” parameter, the path to the user help is entered. User help will be invoked if the focus is on form control. If the focus is on the “Cancel” or “OK” buttons, the help of standard elements will open.
CAD software MechWizard 103Input field. The input field is used to enter numeric or symbolic expressions for further processing.
Properties command:
View
Visible
CAD drawing MechWizard 104
Alignment
On the edge
Multiline
CAD drafting MechWizard 105
Flat
CAD software MechWizard 106
Tip
Linking
(None)
Enable
CAD drawing MechWizard 107
Text
None
Formatting
CAD drafting MechWizard 108
Basic
Name
editbox1
Class
After entering
Variable
Type
Line
Position
Upper limit56
Height
56
Left boundary
176
Lower limit
112
Right boundary
232
Width
56
Measurements
Meter
CAD software MechWizard 109
Mode
Auto
Regime change
CAD drawing MechWizard 110
Developments
Activation
Deactivation
To change
CAD drafting MechWizard 111Checkbox. Allows you to monitor on/off.
Properties command:
View
Visible
CAD software MechWizard 112
Tip
Linking
(None)
Allowed
CAD drawing MechWizard 113
Text
Flag
Basic
Enabled
CAD drafting MechWizard 114
Name
checkbox
Class
Flag
Variable
Position
Upper limit
8
Height
16
Left boundary
8
Lower limit
24
Right boundary
72
Width
64
Developments
by clicking
CAD software MechWizard 115Switch .Switches to monitor the status on/off. Several individual switches interconnected to form a “group switch” to track more states. Example of use of the group switch.
Description:
Several switches are associated with the same variable script. Each of them set any value. Variable is set to the included switch. Value is of type string. If set to “-1” value is assigned automatically starting with 1, in the tab order for TAB. In this case, the value type is numeric. Switches associated with a single variable group are considered. In the group may be included in only one switch. If a variable is assigned, grouped switches located inside one of the control. Usually this group or panel.
Properties command:
View
Visible
CAD drawing MechWizard 116
Tip
Linking
(None)
enabled
CAD drafting MechWizard 117
Text
Switch
Basic
Included
CAD software MechWizard 118
Value
-1
Name
radiobutton
Class
Switch
Variable
Position
Upper limit
24
Height
24
left boundary
8
Lower limit
48
Right boundary
112
Width
104
Developments
by pressing
Example of using.
Switches allow you to choose between discrete values, the result is displayed in the input field
CAD drawing MechWizard 119
CAD drafting MechWizard 120List. Used to select one value from a specified list.
Properties command:
View
Visible
CAD software MechWizard 121
Tip
Linking
(None)
Enable
CAD drawing MechWizard 122
Text
-1
Basic
Data
“Element 1”
Name
Listbox
Class
List
Variable
Current
-1
Position
Upper limit48
Height
40
Left boundary8
Lower limit
88
Right boundary
104
Width
96
Developments
Activation
Deactivation
To change
CAD drafting MechWizard 123List from the database.. Used to select one value from a pre-specified list in the database.
Properties command:
View
Visible
CAD software MechWizard 124
Tip
Linking
(None)
Enable
CAD drawing MechWizard 125
Text
Basic
Data
Name
Listbox1
Class
List of base
Variable
Current
Position
Upper limit
96
Height
60
Left boundary
8
Lower limit
156
Right boundary
104
Width
96
Developments
Activation
Deactivation
To change
CAD drafting MechWizard 126Combo box. Designed to select from the specified list or enter an arbitrary value.
Properties command
View
Visible
CAD software MechWizard 127
Tip
Linking
(None)
enabled
CAD drawing MechWizard 128
Text
Combo box
Basic
Data
Name
combobox
Class
combobox
Variable
Editable
CAD drafting MechWizard 129
Position
upper limit168
Height
76
left boundary
8
Lower limit
244
Right boundary
104
Width
96
Developments
activation
deactivation
to change
CAD software MechWizard 130Combo box from the database. Designed to select from the specified list or enter an arbitrary value.
Properties command:
View
Visible
CAD drawing MechWizard 131
Tip
Linking
(None)
Enabled
CAD drafting MechWizard 132
Text
Basic
Data
Name
combobox1
Class
combobox
Variable
Editable
CAD software MechWizard 133
Position
Upper limit208
Height
64
Left boundary8
Lower limit
272
Right boundary
104
Width
96
Developments
Activation
Deactivation
To change
CAD drawing MechWizard 134Text . Static (non-editable) text formatting support. Specify the formatting is applied to the entire text.
Properties command:
View
Visible
CAD drafting MechWizard 135
Headset
(Info)
Tip
Linking
(None)
Transparent
CAD software MechWizard 136
Text
Text
Background
Basic
Name
static
Class
Text
Label
Variable
Position
Upper limit
280
Height
32
Left boundary
8
Lower limit
312
Right boundary
104
Width
96
CAD drawing MechWizard 137Group. Decorative element, designed to visually group several controls on the form.
Properties command:
View
Visible
CAD drafting MechWizard 138
Tip
Linking
(None)
Enabled
CAD software MechWizard 139
Text
Basic
Name
groupbox1
Class
Group
Variable
Position
Upper limit
320
Height
38
Left boundary
8
Lower limit
358
Right boundary
104
Width
96
Developments
Activation
Deactivation
To change
CAD drawing MechWizard 140Figure. Insert a simple bitmap to the form.
Properties command.:
Basic
Name
Class
Drawing
Variable
View
Visible
CAD drafting MechWizard 141
Data
(Info)
Tip
Linking
(None)
Transparent
CAD software MechWizard 142
Proportionally
CAD drawing MechWizard 143
Stretch
CAD drafting MechWizard 144
Position
Upper limit
360
Height
57
Lleft boundary
8
Lower limit
417
Right boundary
105
Width
97
CAD software MechWizard 145Panel. Designed for grouping and align multiple controls on the form.
Properties command:
Basic
Name
panel
Class
Panel
View
Linking
(None)
Position
Upper limit16
Height
49
Left boundary
112
Lower limit
65
Right boundary
185
Width
73
CAD drawing MechWizard 146Button. Control “button.” Response by pressing the left mouse button.
Properties command:
View
Visible
CAD drafting MechWizard 147
Tooltip
Linking
(None)
Allowed
CAD software MechWizard 148
Text
Button
Main
Icon
-1
Name
button
Class
Button
Variable
Position
Upper Bound
72
Height
32
Left bound
112
Lower limit
104
Right border
184
Width
72
Developments
by clicking
CAD drawing MechWizard 149Table with filtering. Table variables to restrict the number of columns, and automatic filtering of the list columns.
Properties command:
Basic
Name
Control
Class
Variable
View
Visible
CAD drafting MechWizard 150
Tip
Linking
(None)
Enable
CAD software MechWizard 151
Position
Upper limit
112
Height
32
Left boundary
112
Lower limit
144
Right boundary
184
Width
72
CAD drawing MechWizard 152Table . Table variables with the ability to view and select a row.
Properties command:
Basic
Name
Control1
Class
Variable
View
Visible
CAD drafting MechWizard 153
Tip
Linking
(None)
Enable
CAD software MechWizard 154
Position
Upper boundary
152
Height
40
Left boundary112
Lower limit
192
Right boundary
184
Width
72
CAD drawing MechWizard 155Views and performance. Table for selection and execution of standard projection of the object from the database.
Properties command:
View
Visible
CAD drafting MechWizard 156
Tip
Linking
(None)
Enable
CAD software MechWizard 157
Basic
Name
Control2
Class
Execution
Show performance
CAD drawing MechWizard 158
Types
CAD drafting MechWizard 159
CAD software MechWizard 160
CAD drawing MechWizard 161
CAD drafting MechWizard 162
CAD software MechWizard 163
CAD drawing MechWizard 164
CAD drafting MechWizard 165
CAD software MechWizard 166
CAD drawing MechWizard 167
CAD drafting MechWizard 168
CAD software MechWizard 169
CAD drawing MechWizard 170
Display Types
CAD drafting MechWizard 171
Shows the type form
CAD software MechWizard 172
Position
Upper limit
200
Height
32
Left boundary
112
Lower limit
232
Right boundary
184
Width
72
CAD drawing MechWizard 173Preview. Preview box of the selected object from the database.
Properties command:
View
Visible
CAD drafting MechWizard 174
Tip
Linking
(None)
Enabled
CAD software MechWizard 175
Text
PreViewControl
Basic
Name
control3
Class
Review
Position
Upper limit
240
Height
40
Left boundary112
Lower limit
280
Right boundary
184
Width
72
Collection Editor
Serves for quick creation of lists and their subsequent use in form controls and custom sorting in tables.
Dialog
The dialog is divided into two parts: Collection name and Collection members.
CAD drawing MechWizard 176
Collection management tools
CAD drafting MechWizard 177Add new collection.
CAD software MechWizard 178Delete collection.
Collection members management tools
CAD drawing MechWizard 179Add new collection member.
CAD drafting MechWizard 180Delete collection member.
CAD software MechWizard 181Delete all collection members.
CAD drawing MechWizard 182Move collection member upper.
CAD drafting MechWizard 183Move collection member down.
CAD software MechWizard 184Paste from clipboard.
Create and assign a collection while editing a form
In order to create a collection you need to:
1. Click the “Data” option in the DB-Listbox or DB-combobox. A dialog box will appear. 2. In the list of collections, call the CAD drawing MechWizard 185“Add new collection” command and enter a name for the collection. CAD drafting MechWizard 186 3. Set the composition of the collection. CAD software MechWizard 187 CAD drawing MechWizard 188 4. Select a collection and click “OK” in the Collection Editor dialog box. 5. he created collection will look like this: CAD drafting MechWizard 189Creating custom filtering on a table
1. Go to Edit Table Dialog “Main Menu – Rows – Custom Sort…”. 2. In the list of collections, run the CAD software MechWizard 190“Add new collection” command and enter a name for the collection. CAD drawing MechWizard 191 3. Set the composition of the collection. CAD drafting MechWizard 192 CAD software MechWizard 193 4. Click “OK” in the Collection Editor window.Purpose of custom filtering in a table
1. In the “Row grouping and merging” dialog box add a “User Sort” rule.CAD drawing MechWizard 194
2. Select a collection and click “OK”. 3. The custom sort created will look like this: CAD drafting MechWizard 195Important!
Collections are saved to the database, they can be used in other objects nanoCAD Construction 23.
Forms and tables have separate stores.
Collections created by editors or administrators are available to everyone and cannot be edited by the user (the collection editing buttons will be grayed out).
User-created collections are only accessible to the user.
Table resources
Section Table of resources designed to create a multilingual resource strings details.
CAD software MechWizard 196
In the context menu section, there are options to add and delete rows.
CAD drawing MechWizard 197
Each resource can have a name (Label), by which it will be referenced from the script (by writing the @Resource Name ). The property is selected, the row that corresponds to the name of the resource (or its ID) and the column corresponding to the application language. Thus, we can ensure the correct operation of applications of different locations on the same database. Of course, the current local line must be completed, otherwise for non-Russian locale is selected resource corresponding to the English language.
Script
When switching to the section script in the workspace displays the script object.
CAD drafting MechWizard 198
In the context menu of the script contains option parsing script.
CAD software MechWizard 199
While parsing the functions performed consistently script object and passed to the notification system error messages. By double-clicking on a line in the notification area on the transition line of the script that contains the error.
CAD drawing MechWizard 200
CAD drafting MechWizard 201Main menu: Construction – Library objects – MechWizard – CAD software MechWizard 202Add constraint.
CAD drawing MechWizard 203Ribbon: Construction – MechWizard – CAD drafting MechWizard 204Add constraint.
CAD software MechWizard 205Toolbar: CAD drawing MechWizard 206Add constraint ( “MechWizard”).
CAD drafting MechWizard 207Command line: SPCONSTRAINT.
In the dialog box Constraints:
CAD software MechWizard 208
In the dialog box set parametric and assembly (geometric) dependencies between database objects.
The window is divided into two parts:
Left – The child
Right – The parent object
Use CAD drawing MechWizard 2091-selected object and 2 were selected to the choice made in the drawing, respectively subsidiary and parent objects. After selecting an object in the corresponding half of the window, a list of parameters of the object, which includes:
· Property name · List surfaces (work surfaces) · The list object’s parameters · List of installed parametric relationships · List of installed assembly constraintsCAD drafting MechWizard 210
On two tabs depending Parametric and Assembly constraints established relationship between parent and child objects.
Parametric dependence connects the parameters of objects.
Assembly dependence binds workplanes objects.
Button CAD software MechWizard 211 New dependency. Allows you to create a new dependency
Button CAD drawing MechWizard 212 Delete dependency. Deletes the selected list dependence
When adding or editing button is activated depending CAD drafting MechWizard 213Save dependence, which allows you to save your changes.
Installing the parametric dependence
When installing the parametric constraints is associated parameters are recorded in the corresponding input fields located below the list object’s parameters. Selecting the link parameters by double-clicking on the corresponding parameters in the list.
CAD software MechWizard 214
Installing assembly according
To install the switch assembly according to the tab Assembly constraints.
Choose binding surface by double-clicking on the appropriate working plane from the list.
CAD drawing MechWizard 215
Selecting the plane can also be done visually in the drawing by clicking labelled plane and the linked marker indicating the working plane of the object.
CAD drafting MechWizard 216
The choice of method depends overlay using the buttons at the bottom:
CAD software MechWizard 217Axial and surface alignment
CAD drawing MechWizard 218Surface alignment
CAD drafting MechWizard 219Combination axis
CAD software MechWizard 220Direction
Choose mutual orientation related planes using the buttons:
CAD drawing MechWizard 221Counter-directional
CAD drafting MechWizard 222Codirectional
Button CAD software MechWizard 223 Bidirectional constraint. Enables two-way relationship in which a related parameter or surface of the parent object changes with appropriate changes to the child object.
Compound objects
CAD drawing MechWizard 224Main menu: Construction – Library objects – MechWizard – CAD drafting MechWizard 225Connect objects.
CAD software MechWizard 226Ribbon: Construction – MechWizard – CAD drawing MechWizard 227Connect objects.
CAD drafting MechWizard 228Toolbar: CAD software MechWizard 229Connect objects ( “MechWizard”).
CAD drawing MechWizard 230Command line: SPCONNECTTO.
This command is used to overlay preset assembly and parametric dependencies on objects in the drawing.
After running the command must specify.
1. Child object – an object that will be joining. 2. Parent object – the object to which you will attach the child object.Upon completion of the command will be imposed on the details of parametric and geometric constraints defined in their script..
Symmetry axis
CAD drafting MechWizard 231Main menu: Construction – Library objects – MechWizard – CAD software MechWizard 232Symmetry axis.
CAD drawing MechWizard 233Ribbon: Construction – MechWizard – CAD drafting MechWizard 234Symmetry axis.
CAD software MechWizard 235Toolbar: CAD drawing MechWizard 236Symmetry axis ( “MechWizard”).
CAD drafting MechWizard 237Command line: SPWIZSYM.
Select the segment to set it as the axis of symmetry. Drawing can contain multiple axes of symmetry. Symmetrical layout sketch relating to a particular axis is determined automatically by the recognition of a parametric model.
Set Parameter
CAD software MechWizard 238Main menu: Construction – Library objects – MechWizard – CAD drawing MechWizard 239Set Parameter.
CAD drafting MechWizard 240Ribbon: Construction – MechWizard – CAD software MechWizard 241Set Parameter.
CAD drawing MechWizard 242Toolbar: CAD drafting MechWizard 243Set Parameter ( “MechWizard”).
CAD software MechWizard 244Command line: SPWIZPARAM.
Button Set parameter is used for setting targets sketch. Press the button and select the object (sketch element). This will bring up a dialog box, the form of which depends on which object was selected.
Setting size
When setting the size of the dialog box will look like:
CAD drawing MechWizard 245
Enter a parameter expression to control the size. The parameter can be set by a variable name or expression that is allowed to use the number and names of the variables related to mathematical and logical functions.
Important!
Object parameter names should not coincide with the names of the teams nanoCAD (for example, can not be assigned to the parameter name HATCH or LINE)
Expressions can be used the following functions:
· arithmetic operators +, -, *, / · trigonometric functions sin(), cos(), tg() (the function argument is given in degrees) · inverse trigonometric functions asin(), acos(), atg() · taking the square root function sqrt() · exponentiation function^ (recording format: x ^ y – x raising y) · absolute value abs() · rounded to an integer value int().Logical operations:
· Min(x,y) – returns the minimum value of the argument; · Max(x,y) – returns the greatest value. · Iff (boolean, x, y) – returns the value of the argument x if the logical expression is true, or the value of y if the logical expression is false. Example of using the function, the result of which is similar to the function Min (x, y): Iff(x<y, x, y).Valid logical conditions: >, <, == (equal), ! = (Not equal), > = (not less than), <= (not more).
Function within an expression can be nested.
Setting the graphic element
When you set a graphic element sketch (segment, circle arc, circle, spline or shading) dialog box will look like:
CAD drafting MechWizard 246
Work items are supporting the construction of a thumbnail and are not displayed when you insert a model from the database. Performance object can be any graphic sketch element: line, arc of a circle, etc.
Setting the insertion point
When setting the insertion point, a dialog box will look like:
CAD software MechWizard 247
Distance along the axes OX and OY determines the position of the handle in the object. Distance can be set expression or numeric value.
Parameter on the x-axis and OX and OY is the name of the script variable whose value will change when stretching the handle.
Button CAD drawing MechWizard 248 specify parameter lets take a parameter or drawing away.
Enter additional values
In the sketch may include additional expressions for calculation of parameters. These expressions should be written a single line text entry format each line of text as follows:
X = EXPR
where X – the variable name;
EXPR – an expression that contains the names of variables, mathematical or logical functions.
Examples of additional rows of values:
· a = b*2 – assigning the result of an arithmetic operation; · alpha = asin(b/c) – the use of trigonometric functions; · k = iff(a>b, 1, 0) – assign a value to the condition; · d = min(m1, 100) – the assignment of the smallest of the two values; · g10 = sin(alpha*2) + sqrt(b^2 – c^3) / min(sin(a), cos(b)) – nested functions.Sequence computing additional rows values – from left to right and top to bottom. Additional values values recognizing parametric form must be selected along with other sketch entities.
Insert point
CAD drafting MechWizard 249Main menu: Construction – Library objects – MechWizard – CAD software MechWizard 250Insert point.
CAD drawing MechWizard 251Ribbon: Construction – MechWizard – CAD drafting MechWizard 252Insert point.
CAD software MechWizard 253Toolbar: CAD drawing MechWizard 254Insert point ( “MechWizard”).
CAD drafting MechWizard 255Command line: SPWIZINS.
The insertion point should always be shown on the sketch of the parametric model. Click to choose its position on the sketch.
If you try to check the model or recognize the form of a sketch in which the insertion point is not specified on the command line, you are prompted to “Select insert point”. Then you need to specify the sketch position of the insertion point.
In the case of several insertion points in the sketch, recognition will be considered only of the one that has been specified later, and all others will be ignored.
Suppression contour
CAD software MechWizard 256Main menu: Construction – Library objects – MechWizard – CAD drawing MechWizard 257Supression contour.
CAD drafting MechWizard 258Ribbon: Construction – MechWizard – CAD software MechWizard 259Supression contour.
CAD drawing MechWizard 260Toolbar: CAD drafting MechWizard 261Suppression contour.
CAD software MechWizard 262Command line: SPWIZCONTOUR.
Important!
The command prepares the sketch for recognizing the execution type of the base object.
A suppression contour limits the area that the object overlaps with other graphics in the drawing. If the suppression contour is not specified, it is created automatically when the model is recognized by the external outlines of the part, and service objects are not taken into account.
1. Draw a closed polyline on the sketch that matches the shape and size of the required suppression contour (in the figure, a rectangle around the sketch).
CAD drawing MechWizard 263
2. Call the command CAD drafting MechWizard 264“Supression contour”.
3. Specify the constructed polyline. The contour is highlighted in green in the sketch.
CAD software MechWizard 265
A prerequisite for the contour is the absence of self-intersections. To avoid self-intersections for a compound contour, create the contour manually, leaving a minimum “isthmus” between the areas:
Wrong
Right
CAD drawing MechWizard 266
CAD drafting MechWizard 267
If the suppression contour cannot be created automatically (the outer boundaries of the object do not form a closed contour), then when the object is inserted into the drawing, a corresponding warning message will be displayed. However, errors in the suppression contour do not affect the applicability of the recognized object, and can only appear in the wrong overlap of other objects in the drawing.
Hatch contour
CAD software MechWizard 268Main menu: Construction – Library objects – MechWizard – CAD drawing MechWizard 269Hatch contour.
CAD drafting MechWizard 270Ribbon: Construction – MechWizard – CAD software MechWizard 271Hatch contour.
CAD drawing MechWizard 272Toolbar: MechWizard – CAD drafting MechWizard 273Hatch contour.
CAD software MechWizard 274Command line: SPWIZSECTCONTOUR.
Important!
A hatch contour defines the shaded area of an object in the drawing.
1. Draw a closed polyline in the sketch that matches the shape and size of the required hatch contour (in the figure, a rectangle around the sketch).
CAD drawing MechWizard 275
2. Call the command CAD drafting MechWizard 276“Hatch contour”.
3. Select the constructed polyline. The outline will be highlighted in red in the sketch.
CAD software MechWizard 277
A prerequisite for the contour is the absence of self-intersections. To avoid self-intersections on a compound contour, create the contour manually, leaving a minimum “isthmus” between the areas.
Wrong
Right
CAD drawing MechWizard 278
CAD drafting MechWizard 279
Array
CAD software MechWizard 280Main menu: Construction – Library objects – MechWizard – CAD drawing MechWizard 281Parametric model.
CAD drafting MechWizard 282Ribbon: Construction – MechWizard – CAD software MechWizard 283Parametric model.
CAD drawing MechWizard 284Toolbar: CAD drafting MechWizard 285Parametric model ( “MechWizard”).
CAD software MechWizard 286Command line: SPWIZARR.
1. Create primitives of nanoCAD block and select the required dimensions in the sketch to determine its size and location. 2. Press the CAD drawing MechWizard 287array and selected block in the drawing. 3. In the dialog box, select an array type and parameters that control the construction of the array. Parameters can be assigned to both numeric and non-numeric values (variable names and expressions).CAD drafting MechWizard 288
Every single unit with a unique name that is inserted into a sketch can be used only in a single array.
Test Model
CAD software MechWizard 289Main menu: Construction – Library objects – MechWizard – CAD drawing MechWizard 290Test model.
CAD drafting MechWizard 291Ribbon: Construction – MechWizard – CAD software MechWizard 292Test model.
CAD drawing MechWizard 293Toolbar: CAD drafting MechWizard 294Test model ( “MechWizard”).
CAD software MechWizard 295Command line: SPWIZ.
Checks sketch of a parametric model.
Highlight crossing window thumbnail and press Enter. If the sketch contains no errors, a message appears
If the sketch is not large enough, a message appears warning of an error.
Create sketch
The sketch is the original model of the parametric view of the object.
CAD drawing MechWizard 296
When creating parametric objects, the commands of the “MechWizard” toolbar are used.
1. Prepare a sketch. For correct recognition, all graphic elements of the sketch (including hatching) must be drawn with the appropriate linetype. Similar types (solid thick and thin, dash-dotted thin and thick) should be distinguished by the color set in the nanoCAD Construction settings.
CAD drafting MechWizard 297
2. Set the insertion point, optionally specify the axis of symmetry, sketch element options, suppression contour, hatch contour and paramentric array.
CAD software MechWizard 298
3. Dimension and assign variables and expressions to them.
CAD drawing MechWizard 299
4. Enter additional parameters as needed.
CAD drafting MechWizard 300
5. Check the sketch and make sure there are no errors.
CAD software MechWizard 301
Examples
Example of creating a template layout tiles.
1. Create a sketch of the object. If the size of the tiles will not change, then the sketch is not required to specify the size. Terms and method of creating a sketch of the parametric object described in section Rules for creating sketches .CAD drawing MechWizard 302
2. Create an object and save it to the database. In a script, you must set the variable “type” (strTheType = “Plate”) 3. Position the Bone in the drawing, insert the base of the two vectors and create a group. (see. Create user group ). These vectors determine the pace and direction of replication of the original group. The basic point of the vector must coincide with the insertion point of the object. CAD drafting MechWizard 303If only one vector will create one line layout in any mode selection area.
