Collecting multileaders
Ribbon: Home, Annotate – Leaders – Multileader Collect
Toolbar: Mleaders –
Command line: MLEADERCOLLECT
Collecting several multileaders containing blocks in one with horizontal or vertical location of blocks.
Vertical | Specifies options for spacing and aligning the selected multileaders. The command memorizes and by default uses the align method specified last time. |
Horizontal | Leader landings with the content will be evenly distributed between two points specified on the screen |
Wrap | Specifies a width value for a wrapped multileader collection. |
Specify wrap width | Wrap width. |
Number | Maximum number of blocks per row in the multileader collection. |
Select multileaders or [?]: | Specify the multileaders to be collected. Multileaders without blocks will be excluded from the selection. The blocks will be placed in the order of selecting multileaders. An extension line of the last selected leader will be saved. |
Specify the position of collected multileader or [Vertical/Horizontal/Wrap]: | Select the method to collect multileaders (horizontal or vertical) and specify the location of its content in the drawing workspace. |
Info: NanoCAD is a user friendly, inexpensive, and yet powerful, CAD application for PC, that provides an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our tool provides innovative, collaborative and customizable features to improve your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
