Snap and Grid mode
Menu: Tools – Drafting settings… > Snap and Grid tab
Status bar: and
Hotkeys: F9 and F7
Command line: DDRMODES, DSETTINGS, SE
Grid is an ordered sequence of points, which with SNAP mode allows specifying restrictions of the cursor movement to define accurate coordinates. You can switch the grid on/off at any time when you are working with a drawing. Changing grid spacing does not affect any drawing objects.
Grid is not printable.
If SNAP mode is switched on, the cursor jumps from node to node with the specified snap spacing. Snap spacing and grid spacing can be different but very often their values are the same. Grid can have high spacing and snap spacing can be small to give a user the capability to specify points of high precision. For example, you can set grid spacing to 10 units, and snap spacing to 1 unit. Grid and snap spacing can be different along the X and Y axes.
Major line – additional lines are also highlighted:
Adaptive grid – grid display depends on the drawing scale. When zooming in, additional grid lines appear; when zooming out, they disappear. The frequency of these lines is determined by the frequency of the main grid lines.
A grid showing drawing limits, allows visualization of the drawing dimensions to place base elements on the initial stages.
The parameters of the SNAP and GRID modes are specified in the Snap and Grid tab of the Drafting settings dialog box or in the context menus.
Tab parameters:
Snap On (F9): Switches snap mode on/off. Grid snap mode can also be turned on/off by the button in the status bar, F9 key or SNAPMODE system variable..
Snap spacing
Snap Х spacing: Specifies the X spacing. The value should be a positive real number. (SNAPUNIT system variable).
Snap Y spacing: Specifies the Y spacing. The value should be a positive real number. (SNAPUNIT system variable).
Equal X and Y spacing: Sets equal spacing between X and Y. Snap spacing may differ from grid spacing.
_ Polar snap_
spacing: Specifies a snap when setting the polar snap mode (POLARDIST system variable). When set to zero, a polar snap spacing is equal to snap spacing by X. A polar snap only works when polar and/or object tracking is enabled..
Snap type
Grid snap: Specifies a grid snap for the cursor movement to horizontal and vertical grid points (SNAPTYPE system variable). Rectangular: Specifies the standard mode for rectangular snap. In case of grid and rectangular snap type, the cursor moves along the rectangular structure nodes. (SNAPSTYL system variable). Isometric: Specifies the mode of isometric snap and activates the isometric drafting mode. In case of grid and isometric snap type, the cursor moves along the isometric grid nodes. (SNAPSTYL system variable).
Polar: Specifies the polar snap. With polar snap and enabled polar tracking, the cursor can move along imaginary lines drawn from the tracking base point at the angles specified on the Tracking tab. (SNAPTYPE system variable). To use the polar snap in the isometric drafting mode, you should first set the isometric snap, and then switch to polar snap:
Grid:
Grid on (F7): Enables/Disables the display of grid on the screen. The grid mode can also be turned on/off using button in the status bar, F7 key or GRIDMODE system variable.
Grid spacing
Snap X spacing: Specifies the distance between grip nodes by X axis. When set to zero, a grip spacing is equal to a grip snap (GRIDUNIT system variable).
Snap Y spacing: Specifies the distance between grip nodes by Y axis. When set to zero, a grip spacing is equal to a grip snap (GRIDUNIT system variable).
Major line every: Specifies the number of grip nodes through which the main (thickened) grip lines are displayed (GRIDMAJOR system variable).
Grid behavior
Adaptive grid: Switches adaptive grid mode on/off.
Allow subdivision below grid spacing : Switches division of the grid spacing on/off.
Display grid beyond limits: Switches display of the grid beyond specified limits on/off.
Follow Dynamic UCS: Sets the grid plane in accordance with XY plane of dynamic UCS (GRIDDISPLAY system variable).
The context menu of the* SNAP* button:
Parameters:
Set snap steps: Specifies the X and Y spacings in the command line (SNAPUNIT variable).
Setup…: Opens the Drafting settings dialog box.
On : Switches snap mode on/off.
The context menu of the GRID button:
Parameters:
Set grid steps: Specifies the X and Y spacing in the command line.
Set grid limits: Specifies the limits of the grid display.
Infinite grid: Switches off restrictions for the grid display.
Setup… Opens the Drafting settings dialog box.
On Switches display of the grid on/off.
Info: NanoCAD is an easy-to-use, cheap, and yet powerful, CAD application for PC, that delivers a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our freeware ensures progressive, collaborative and customizable features to raise your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and buy later, if you like it.
