Creating bergstriches
Ribbon: Topoplan – Relief > Bergstriches
Menu: Ground – Elevation > Bergstriches
Toolbar: Elevation > Bergstriches
Command line: NG_CREATE_BERGSTRICH
The command will create a bergstrich (in the form of block) at the specified location of the contour.
To create a bergstrich:
1. Run the command.
2. In response to the prompt in the command line
Specify bergstrich position:
click the left mouse button in the required place on the contour line.
3. In the specified place bergstrich will be created in form of block named CONTOUR_BERG.
4. Several bergstriches can be created in succession. Pressing ESC button ends the command.
Info: NanoCAD is an easy-to-use, inexpensive, and yet powerful, CAD program for personal computer, that provides a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our tool supports creative, collaborative and customizable features to improve your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
