nanoCAD
Table of Contents
nanoCAD
General Information
Introduction
System Requirements
Program Installation
Program Registration
Launch of nanoCAD
Help System
Exit from nanoCAD
Trademarks
nanoCAD User Interface
Working with Commands
Redo Commands
Undo Commands
Undo-Redo Commands
Settings of the Right Button
User Interface
Interface. The nanoCAD Button
Quick Access Toolbar
Interface. Ribbon
Interface. Main Menu
Interface. Toolbars
Interface. Drawing Window
Interface. Context Menu
Interface. Properties Bar
Command Line
Status Bar
Restore UI State
Managing Interface Elements
Application Look
Working With Documents
Creation of New Document
New Document Creation
Template Usage
Saving a Document
Saving Document
Auto Saving and Backup
Export
Exports
Integration with CAE Fidesys
CAD Standards
CAD Standard
Creating a Standards File
Checking Standards
Standards Check Options
Utilities
Utility
Document audit
Audit geometry
Recovery of document
Purging of document
Convert to 2D
Text Encoding Conversion
Work with Documents
Opening a Document
Drawing Properties
Closing a Document
Import
Import PDF
Importing PDF Underlay Data
Create Transmittal Package
File Explorer
Drawing Comparison
Tuning nanoCAD
Transferring user interface
Tuning program parameters
Profiles
Profile quick setting
Graphic subsystem settings
Customize User Interface
Customize Users Interface
Ribbon Tab
Main Menu
Toolbars Tab
Toolbars Display Settings
Accelerators Tab
Object Actions Tab
Status Bar Tab
Rollover Tooltips Tab
Aliases Tab
Create New Command
Create Virtual Command
Design settings
Design setting
Main Options Tab
Standard Elements Tab
Symbols Tab
The Forms tab
3D Tab
Settings of Layers profiles
Drawing units
Scale List
System Variable Monitor
Coordinate Systems
User Coordinate System 16000
UCS Icon
Named UCS
UCS for viewports
Coordinate system
Aligning UCS to an Object
New Origin for UCS
UCS View
Changing direction of Z axis
Dynamic UCS
Precision tools
Precision tools
Snap and Grid mode
Snap and Grid Modes
Drawing limits
Snap to raster objects
Snap to Raster Object
Settings of raster snap
Precision mode
Polar Tracking mode
Object snap mode
Object Snap tracking mode
Display of snap elements
ORTHO mode
Dynamic Input
Precision Tools
2D Constraints
Graphic Display Management
3D Navigation
3D Orbit
Free Orbit
3D-Navigation View Modes
3D-Fly
3D-Walk
Plan
Bounding Prism
View cutting planes
Order of objects
Order of object
Bring to Front
Send to Back
Bring Forward
Send Backward
Bring Texts to the Front
Bring Dimensions to the Front
Send Hatches to the Back
Isolate Objects
Hide Objects
Undo isolation step
Redo isolation step
Unisolate Object
Viewports of Model Space
Viewport of Model Space
Display modes
Visual styles
Managing named views
Isodraft
Drawing regeneration
Objects’ Properties
Line Types
Line Type
Line type Editor
“Properties” bar
Properties panel
Layers
Tools to work with layers
Make Object’s layer current
Layer walk
Match layer
Change to current layer
Copy objects to new layer
Isolate
Layer off
Turn on all layers
Layer freeze
Thaw all layers
Layer lock
Layer unlock
Merge layer
Delete layer
Tools to Work with Layers
Layers Dialog Box
Layer previous
Objects’ Property
Drawing Explorer
Select Color Dialog Box
Geometric objects
Point
Infinite Lines
Linear Objects
Line by two points
Polyline
3D Polyline
Multiline
Multiline Styles
Polygon
Rectangle by two points
Rectangle by three points
Helix
Curved Objects
Curved object
Arc by three points
Arc by start, center and end
Arc by start, end and angle
Arc by start, end and radius
Circle by center and radius
Circle by center and diameter
Circle by diameter
Circle by three points
Donut
Splines
Ellipse
Add selected
Geometric object
Size and style of points
Editing Objects
Selection of objects
Selection of all objects
Remove from Selection
Leave in Selection
Invert Selection
Select Similar Objects
Quick selection of object
Object Selection
Ways to edit objects
Ways to edit object
Copy of Objects Properties
Copy object
Lengthen Objects
Trim Vectors
Smart Trim
Extend Vectors
Break Vectors
Break Vectors at Point
Break All Vectors at Point
Reverses
Join Object
Editing a Polyline
Editing a Spline
Simplify Splines
Commands to edit objects
Erase
Copy
Mirror
Offset
Array
3D Array
Delete duplicates
Move
Rotate
Scale
Stretch
Align
Distributing copies
Divide
Measure
Chamfer
Fillet
Explode
Explode all nanoCAD objects
Editing object
Blocks
Block
Creating a Block
Block Insertion
Block Attributes
Creating Block Attributes
Block Attribute Manager
In-Place Attribute Editing
Block Editor
Proxy Objects
Proxy Object
Removing Proxy Objects
Exploding Proxy Objects
External references control
External reference control
Bind external references
Renaming Named Objects
Underlays
Underlay
Insert Underlay
Show boundary
Show boundary definition
Boundary
Groups of objects
Insert External Reference
Edit references
Exploding a block reference
Hyperlinks
Working with raster images
New Image from Selection
Save Objects to a File
Save Screenshot to a File
New Image
Image Adjust
Image Quality
Resizing raster image
Changing image resolution
Cropping of Raster Images
Mirroring
Rotation
Deskewing
Correction by four points
Calibration
Color correction
Color corrections
Correction by histogram
Gamma correction
Editing color palette
Filtering color raster images
Blur
Adaptive Blur
UnSharp Mask
Median
Color reducing
Colour reducing
Binarization
Adaptive binarization
Color Separation
Color reduction
Monochrome filtering
Monochrome filterings
Removing speckle
Filling holes
Smoothing
Thinning
Thickening
Contour
Inversion
Raster drawing
Raster drawings
Pixel drawing
Floodfiling
Editing raster text
Trace modes
Trace methods
Forced tarce
Trace polyline
Conversion options
Recognition tab
Options tab
Separate tab
Trace tab
Texts tab
Train OCR
TIFF saving options
JPG and JPEG saving options
Insert raster image
Separate Raster Image
Embed Raster Image
Image settings
Separation by type and size
Rasterization
The Filling and Hatch command
Gradient fill
Fast Hatch
Fast Gradient
Modify Hatched Areas
Work with Text
Work with Texts
Text
Multiline Text
Editing Text
Creating a text style
Spellchecker
Find and Replace Text
Justify Text
Text Fit
Explode text
Change Text Case
Quick Text mode
Field
Update Field
Edit Field
Convert Field to Text
Dimensioning
Dimensionings
Ordinate dimensioning
Group dimensioning
Base dimensioning
Chain dimensioning
Radial dimensioning
Big radius dimensioning
Diameter dimensioning
Angular dimensions
Arc length dimensioning
Dimensions editing
Dimension editing
Oblique dimension
Break and Restore dimensions
Dimension styles
Dimension style
Modify a dimension style
Multileader
Multileaders
Aligning multileaders
Collecting multileaders
Multileader Style Manager
Notes
Mechanical note
Construction note
Comb leader note
Section note
Node note
Linear aligned note
Chain note
Editing the leaders
Tables
Table
Editing tables on the drawing
Cell Properties dialog
Import, Export from MS Excel
Page Division
Convert tables
Expression builder
Report creation
Grouping and merging cells
Insert material
.dwg Tables
Insert .dwg table
Table Styles .dwg
Getting Inquiry
Distance
Point Coordinates
Cumulative Length
Cumulative Area
List
Inquiry
Mass Properties
Set Variable
The Edit Command
The DDEdit Command
The FEdit Command
The In Place Edit Command
Parameters Redefinition
Regenerate
Shape
Topographic Hatches
Boundary
Region
Solid
Wipeout
Revision Cloud
Calculator
Notepad
3D Modeling and Visualisation
Surfaces
Box
Wedge
Cone
Sphere
Torus
Pyramid
Dish
Dome
Mesh
3D Mesh
3D Face
Light Sources
Light Source
Point Light
Spotlight
Distant Light
Weblight
Materials
Material
Materials Browser
Material Editor
Surface
3D-Component Features
Tool Palettes
Tool Palette
Point Clouds
Point Clouds Display Settings
Point Cloud Display Style
Clip Point Clouds
Point Clouds Section
Information
Point Cloud Info
Point info
Point Cloud
Import of Point Clouds
Export of Point Clouds
Extract from View
Clip Point Clouds by Fence
Clip Undo
Reset All Clips
Point Cloud Vertical Section
Topoplan module
Creating surfaces
Create TIN by points
Exploding a cloud into points
Import elevation grid
Converting model to 3D Faces
Converting model to SubMesh
Tools to work with surfaces
Flip edge
Delete edge
Add vertex
Delete vertex
Change elevation
Moving a vertex
Add structure line
Mesh boundary
Cut mesh
Classification mesh
Create contour lines
Delete Contour Lines
Creating bergstriches
Contour Lines Labels
Building a profile line
Projecting a line onto a mesh
Correction of zero elevation
Texturing and Calculation
Flat Texture Overlay
Raster texture Mapping
Mesh Coloring by Height
Calculting surface area
Calculating surface volume
Import and export
Import geopoints
Import from LandXML
Export to LandXML
Import from GIS
Export to GIS
Importing Geo-linked Rasters
Mesh Seal Holes
2D Slope
3D Slope
Create Geopoints
Adding Edge
Export Geopoints
Mesh Simplification
Topoplan
Work with Layouts
Work with Layout
To create a new layout
Copy layout
Copy layout without viewport
Save a Layout as a template
Delete Layout
Rename Layout
Layouts Manager
Viewports
Viewport
Create a rectangular viewport
Edit Layout Viewports
Change Space
Export Layout to Model
Create a polygonal viewport
Create a viewport by object
Document Plot
Documents plot
Page Setup Manager
Plot Preview
Plot Style Manager
Plot
Batch plot
Internal PDF-plotter
Model space and paper space
EDS
EDSs
Sheet Set
Sheet set tree elements
Sheet Set Properties
Sheet set property
Sheet set custom properties
Blocks in the Sheet Sets
Blocks in the sheet set
View label blocks
Callout blocks
Sheet sets
Create Sheet Set
Open Sheet Set
Software Extensions
Software extension
NRX and LISP file loading
.NET application loading
JScript loading
VBScript loading
NSF files loading
Work with LISP-applications
ncad.lsp
Command scripts
Script Editor
Run from Command Lline
Mechanica Module
INTRO
Basic knowledge
SETTINGS
WORKING WITH STANDARD ELEMENTS
DESIGNING
ENGINEERING ANALYSIS
DRAWING SPECIFICATIONS
DRAWING DESIGN
EDITING
MECHWIZARD
Mechanica UTILITIES
Construction Module
construction MechWizard
Construction INTRO
Construction BASIC KNOWLEDGE
Construction SETTINGS
Construction DRAWING DESIGN
Construction EDITING
Construction UTILITIES
Messages
Save changes?
Saving in demo mode
Switch it to 3D render mode
Version 23
Hide All Features
Add Measurement File
Invert Clip
Copy with Base Point
Isolate Feature
Path Array
Associative Arrays
Setting Clip
Copy OLE-link
Detrmining the Diameter
Paste Special
Determining the Radius
Paste to Original Coordinates
3D Module
Batch File Processing
Explode Geometry
Hide Frames
Create Layouts by Frames
Save to Measurement Archive
Cut
Align the Viewport Objects
Open OLE-Object
Clip Clouds by Cylinder
Update All OLE-Links
Visual Styles Editor
Isolate All Features
Geopoint Object
Paste as Raster
Delete frames
Hide Feature
Paste as Block
Save as Geounderlay
Reset Block
Conventional Signs
Clip Map Underlay
Selection of Overlaid Objects
Point Clouds Data Formats
Object 3D Snap
Unload Map Underlay
Clip Clouds by Sphere
Paste
Arc Text
Show All Features
Feature Isolation Reset
Edit Polyline Segments
Create View Frames
Load map underlay
Import Cloud Data from DBMS
Modular Program Configuration
Isolate Features
Offset of a 3D-Polyline
Insert Map Underlay
Float Document Window
Hatch Dialog Box
Measurement Archive
Create Layer
Insert OLE-Object
Attach GeoUnderlay
3D Block Editor
Import of KML/KMZ files
Import measurements
Updating Links of OLE-Objects
Rectangular Array
New Topoplan
Polar Array
Edit Array
Developer’s Guide Database
Distributing Objects by Layer
Arrays
Groups of Object
Download as PDF
Layers
Layers
Yes
No
Your name *
Your e-mail address *
Comment *
