Commands that control the settings for visibility redefinition of all block attributes in the drawing are located in the menu View – Display > Attributes. Changing visibility state of attributes requires regeneration of the drawing.
The current visibility state of all attributes in a drawing is stored in the ATTMODE system variable. The 0 value of system variable corresponds to turned off state of attributes visibility, 1 – normal state, 2 – turned on.
Ribbon: Home, Insert – Block > Attributes: Normal
Menu: View – Display > Attributes > Normal
Turns on the visibility state of all attributes defined during their creation: visible attributes are displayed on the drawing, invisible are not.
Ribbon: Home, Insert – Block > Attributes: On
Menu: View – Display > Attributes > On
Turns on the visibility state of all attributes, including those that were defined as invisible during creation.
Ribbon: Home, Insert – Block > Attributes: Off
Menu: View – Display > Attributes > Off
Turns off the visibility of all attributes, including those that were defined as visible during creation.
