Ribbon: Home, Annotate – Leaders > Multilayered construction note
Menu: Draw – Notes > Notes for multilayered designs …
Toolbar: Utilities –
Command line: NOTEM
This command opens the Note for multilayered constructions dialog box to set the note options:
Use the icons to add/remove text input fields and to add border:
Add string. | |
Remove string. | |
Line on first string. |
Use the icons to select the style of the extension line:
None. | |
Arrow. | |
Point. | |
Open arrow. | |
Half-arrow. | |
Oblique. | |
Right angle. |
By left edge. | |
By center. | |
By center. |
Other icons:
The Select line icon is used to switch the comb orientation parallel to the specified line on the drawing. The icon is available when you edit the comb leader note inserted into the drawing. |
To create a note for multilayer constructions:
- Select the required note options.
- Click OK.
- Specify a point on the object to which the leader arrow will be directed.
- Specify the shelf position on the drawing.
Info: NanoCAD is a simple, cheap, and yet powerful, CAD software tool for personal computer, that allows an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our program provides progressive, collaborative and customizable features to raise your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
