Merge layer
Ribbon: Home – Layers > Merge layer
Menu: Format – Layer tools > Merge layer
Command line: LAYMRG
Merges selected layers into a specified layer. Objects on merged layers are moved to the specified layer and the initial layers are purged.
Name | Opens the Merge layers dialog to specify objects or layers to merge. |
Select object on layer to merge or [?/Name]: | Select objects on merged layers. |
Select object on layer to merge or [?/Name]: | Select Name option for selection of layers in the list of the Merge layers dialog. |
Select object on layer to merge or [?/Name]: | Press ENTER to finish selection. |
Select object on target layer or [?/Name]: | Select object on a layer where objects of merged layers are replaced. |
Select object on target layer or [?/Name]: | Select Name option for selection of target layer in the list of the Merge to Layer dialog. |
Info: NanoCAD is a user friendly, affordable, and yet professional, CAD freeware tool for personal computer, that provides an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware ensures groundbreaking, collaborative and customizable features to enhance your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
