Flip edge
The surfaces are automatically created according to the Delaunay triangulation rules. Therefore, after creating a TIN, it is often required to edit some areas. Also, in the process of working with relief, sometimes the task of clarifying the surface arises. To do this, the surface editing functionality is used.
To work with surface editing commands, it is recommended to enable shaded visual styles: 3D Flat-shaded with edges, 3D Gouraud-shaded with edges.
Flip edge
Ribbon: Topoplan – Modify TIN > Flip Edge
Menu: Ground – Editing TIN > Flip edge
Toolbar: Editing TIN > Flip edge
Command line: NG_MESH_FLIP
The command changes the edge position between two triangulation faces in the surface model (SubMesh or Polyface mesh); it can be performed, for example, to turn edges along the slope crest, road side, etc.
When you run the command, an object snap is enabled, and then you should specify an edge for a flip.
When you hover the cursor over the mesh, two adjacent triangles the position of face between which will be changed are highlighted in red. A click on the face flips the edge.
Surface before flip Surface after flip
The position of several faces can be subsequently changed. Pressing ESC ends the command.
Info: NanoCAD is a simple, low cost, and yet professional, CAD app for PC, that allows an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our program supports creative, collaborative and customizable features to boost your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and buy later, if you like it.
