Create a polygonal viewport
Ribbon: Layout – Layout Viewports > Add Polygonal Viewport
Menu: View – ViewPorts > Polygonal
Menu: Insert – ViewPorts in Layout > Polygonal
Toolbar: Layout –
Command line: ADDPOLYGONVIEWPORT
nanoCAD allows use of this command on the current layout tab in which the viewport should be located, as well as directly from the model space.
Create a polygonal viewport from the model space
When you create a viewport from the model space, specify the vertex points of the polygonal area of the drawing (in the model space) that should be displayed in the viewport.
Option:
_.Undo | Consistently undo the specified points of the polygonal area. The start point cannot be undone. |
Specify start point: | Specify the start point of the polygonal vertex. |
Specify next point or [Undo]: | Specify the second point of the polygonal vertex. |
Specify next point or [Undo]: | Specify the end point of the polygonal vertex and press ENTER. Select the name of layout in Select Layout dialog to insert a viewport and press OK button. Active before running of command layout is highlighted in the layout list. |
Input or choose view scale <1.000000>: | Input the viewport scale. |
Specify Viewport Center Point: | Specify the viewport center point. |
Create a polygonal viewport from a layout
Extent | Display all objects from the model space in the viewport. |
Active<0.000831> | Display the current view of the model space in the viewport. |
Paper<1.000000> | Set the viewport scale corresponding to the layout scale. |
Specify next point or [Undo]: | Specify the end point of the polygonal vertex and press ENTER. |
Input or choose view scale or [Extents/Active<0.000831>/Paper<1.000000>]: | Input the viewport scale or select the required option. |
Info: NanoCAD is an easy-to-use, affordable, and yet powerful, CAD program for Windows, that provides an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware ensures creative, collaborative and customizable features to improve your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
