Ribbon: Point Clouds – Clip and Section – Section > Unrestricted Section
Menu: Point Clouds – Section > Unrestricted
Toolbar: Point Clouds > Unrestricted Section
Command line: NPC_SECT_UNRESTRICTED
Unrestricted section is performed by 3 points perpendicular to view plane. If there are several viewports in the model space, then it is necessary to specify in which viewport the section result will be displayed.
First and second points determine the vertical plane of section. Third point determines the depth of section.
Create unrestricted section:
- Run the command.
- Specify the first point of section. This point will be located to the left of observer.
- Specify the second point of vertical section. This point will be located to the right of observer.
- Specify the depth of section.
- Select needed view to display the section.
Info: NanoCAD is an easy-to-use, affordable, and yet professional, CAD app for personal computer, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our software supports groundbreaking, collaborative and customizable features to enhance your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
