Select Similar Objects
Ribbon: Home – Utilities > Select Similar Objects
Menu: Edit – Select Similar Objects
Functional toolbar: Properties– !https://manula.r.sizr.io/large/user/13178/img/usso.png!
Command line: SELECTSIMILAR
Command finds all objects within the current drawing that match the properties of selected objects, and then adds them to the selection set. With the Settings option, you specify which properties to match, such as color or block name, in the Select Similar Settings dialog box.
? Additional object selection options.
Settings Displays the Select Similar Settings dialog box, where you can specify which properties to match.
Region Sets rectangular region to select similar objects inside.
Command prompt:
Select patterns or [?/+Settings/Region+] Select object serving as a pattern with desirable properties and select Settings option to set similar properties.
Settings option invokes Select Similar Settings dialog box where similar properties can be defined:
If no property is checked then objects of the same type as pattern object.
If just one property is checked (e.g. Color) then all objects with the color of the pattern object will be selected.
If more than one property are checked (e.g., Color, Layer and Lineweight) then will be selected:
· objects with the color of the pattern object;
· objects with the layer of the pattern object;
· objects with the lineweight of the pattern object.
If property Name is checked then all inserted objects with the same name as of pattern object (blocks, external references and images) will be selected.
To select similar objects in the rectangular region: select Region option then set a rectangular area at the drawing.
Press ENTER to finish the command.
Info: NanoCAD is an easy-to-use, inexpensive, and yet professional, CAD freeware tool for PC, that provides a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our software provides groundbreaking, collaborative and customizable features to enhance your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
