Status Bar Tab
Status bar tab manages elements in the status bar of nanoCAD.
It is possible to add button, control, property, separator to the status bar. Add element by drag and drop from the list of tools. Set the element parameters in Properties.
Add control
1. Select Insert control in the context menu.
2. Set parameters in Create status bar control dialog box.
Add button
1. Select Insert item in the context menu.
Set parameters in Create status bar item dialog box. Item parameters are identical to Create status bar control dialog box.
Add property
1. Select Insert property in the context menu.
Set parameters in Create status bar property dialog box.
Remove status bar elements
1. Select the desired element.
2. Use Delete command in context menu.
Info: NanoCAD is a user friendly, affordable, and yet professional, CAD software tool for Windows, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware ensures innovative, collaborative and customizable features to enhance your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
