Point info
Ribbon: Point Clouds – Calculations and Info > Point Info
Menu: Point Clouds – Calculations and Info > About Point
Toolbar: Point Clouds > Point Info
Command line: NPC_POINT_INFO
Point info displays information about point in the command line. To select point press CTRL and click the point.
Point info displays information about point in the Properites bar. When running the command, the cursor changes to a cross and the Node snap symbol appears.
If there are recognized geometric features in the cloud, it is possible to view the geometric parameters of these features, as well as manage their visibility – isolate or disable their display.
To isolate or hide a feature, click the Feature option in the Properties bar. Two buttons will appear.
Hide Feature
Allows you to hide the feature whose point was selected in the Point Information command. The result is similar to that of the Hide Feature command.
Isolate feature
Allows you to hide the feature whose point was selected in the Point Information command. The result is similar to that of the Isolate Feature command.
Info: NanoCAD is an easy-to-use, low cost, and yet powerful, CAD app for personal computer, that allows a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our program supports innovative, collaborative and customizable features to boost your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and purchase later, if you like it.
