Set Variable
Ribbon: Home – Utilities – Inquiry > Variables
Menu: Tools – Inquiry > Set Variable
Command line: SETVAR
The command displays a list of system variables and allows modifying their values.
The system variables define the mode of command operations. Use the system variables to turn on/off various modes, for example SNAP, GRID, ORTHO. The system variables set the modes of the objects displaying on the screen and their displaying at the print, for example the XCLIP and IMAGEFRAME variables manage displaying of the show borders of the external references and raster images. The system variables are used to set the values used by default, for example the HPSCALE system variable sets the default scale for the hatch patterns. The system variables are used to store information about program settings as well as information about the drawing to display information about the current status of the program settings and to change them.
Enter variable name or ?: | Enter the variable name, for example IMAGEFRAME. |
IMAGEFRAME <1>: | Enter new value of the variable and press ENTER. |
NOTE: You can change the value of the system variables directly in the command line. To do this, type the variable name and press ENTER. Then type new variable name and press ENTER.
Command: imageframe
Command: SETVAR
SETVAR – Enter variable name or
Enter variable name or ?: IMAGEFRAME
IMAGEFRAME <0>: 1
To display a list of the current variables:
- Type the ? as an answer to the prompt Enter variable name or ? and press ENTER.
- Press ESC to finish the command.
- A list of the system variables and their values displayed in the command line. For larger display press the F2:
Info: NanoCAD is a user friendly, cheap, and yet powerful, CAD app for Windows, that provides an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our software supports groundbreaking, collaborative and customizable features to enhance your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
