Save Objects to a File
Ribbon: Raster – File > Save as Image
Menu: Raster > Save Objects to a File
Toolbar: Raster –
Command line: RASTEROUT
The command exports part of drawing to graphic format.
After start you will see prompt with a list of selectable options in the command line.
When the command runs in Model space:
Specify area to rasterize or [Screen/Extents/Window]:
When the command runs in Layout:
Specify area to rasterize or [Screen/Layout/Window]:
Screen | Export the current view of the screen into graphic format. |
Window | Select export area by frame. Specify first window corner: – Specify the first corner of rectangle frame. Specify second window corner: – Specify opposite corner of rectangle frame. |
Extents | Export of all objects. Option is displayed when the command runs in Model space. |
Layout | Export of all layout contents. Option is displayed when the command runs in Layout. |
Further command prompts:
Input file folder or [Browse]: | Press ENTER to save the file in the previous path, or browse the path in dialog by selecting option Browse. |
Input file name : | Press ENTER to save the file under the previous name or enter new name. |
Choose file type or [EMF/WMF/TIF/TIFF/BMP/JPG/JPEG/PNG/PCX]: | Press ENTER to save the file in the previous format or enter other format. |
Specify DPI <300> or [75/150/200/300/400/600/1000/1200]: | Press ENTER to save the file in the previous format or enter other format. |
Info: NanoCAD is a user friendly, inexpensive, and yet professional, CAD freeware tool for Windows, that allows an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our tool provides innovative, collaborative and customizable features to enhance your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
