Checking Standards
Ribbon: Manage – CAD Standards > Check
Menu: Tools – CAD Standards > Check…
Status bar: Check standards
Status bar: context menu of the button Check standards > Check…
Dialog Standards Settings : button Check…
Command line:CHECKSTANDARDS
NOTE: The Standards audit button is displayed in the status bar only if at least one standard file was associated with a drawing.
When checking a drawing for standards violations, the parameters of each named object of a specific type are checked against the corresponding parameters in the corresponding standards files. For example, parameters of each layer in the drawing are checked against the layers parameters specified in the standards file.
The check can be performed both manually and automatically
After the warning appears, you can choose to correct the violation or ignore it.
If you choose to fix the violation, the Check dialog box opens. If it is not required to fix the violation, select Save non-standard object, when the alert appears.
Each detected violation can be fixed or ignored. Information on each detected but not fixed standards violation is saved in the drawing. You can turn off the display of information on such ignored objects the next time you check the drawing.
If there is no preferred fix option for the current standards violation, there will be no options highlighted in the Replace with list, and the Fix button is not available.
A check can uncover two types of errors:
- An object with a nonstandard name in the drawing being checked.
For example, a layer named Wall is present in the drawing, but not found in any associated standards file. - A named object with a standard name has nonstandard properties.
For example, in the drawing the Wall layer has one color, while another color is specified in the standards file for the Wall layer.
Detected elements with nonstandard names are purged from the drawing. All objects associated with the nonstandard element are associated with other element, which replaces that being purged. For example, when detecting a nonstandard layer Wall, it can be replaced with the standard layer Arch-wall. In this case, in the Fix mode of the Check dialog box all objects from the Wall layer are transferred to the Arch-wall layer, then the Wall layer is purged from the drawing.
If in the Check dialog box the Mark this problem as ignored is flagged for the detected violation, then notifications on detected violations related to this named object will not be displayed in future.
Once the entire drawing has been audited, the Check complete message is displayed; it reports all standards violations found in the drawing, as well as the details for violations: fixed automatically, fixed manually, ignored.
Info: NanoCAD is a user friendly, affordable, and yet professional, CAD platform for Windows, that delivers an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our tool provides innovative, collaborative and customizable features to improve your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
