Export of Point Clouds
Ribbon: Point Clouds > Point Cloud > Export
Menu: Point Clouds > Export
Command line: NPC_EXPORT
This command exports point cloud to different formats: LAS (1.2 and 1.4 versions), BIN, XYZ, PLY.
1. The following dialog appears if point cloud has meta data. Select attributes to export in a file. If all checkboxes are turned off, then only point coordinates are exported without attributes.
2. Then specify file format, file name and path.
NOTE: Extension of XYZ file depends on selected attributes: *.xyzciedlastrgb , – for all selected attributes, *.xyz. – without selected attributes.
If the cloud was clipped with one of clip or section commands, then only visible points are exported.
NOTE: Since a clip (or a section) creates for a certain view, then it is very important what model space view is current at the moment of the Export command launching.
If the point cloud has the Class attribute, then only points from visible, unfrozen, unblocked layers will be exported.
Command prompt:
Use all clouds in view? or [Yes/No]: | This prompt is displayed when there are more than one point cloud in the viewport. |
Yes | Exports all visible points of all clouds from the viewport. All points, which are invisible in active viewport, because they are outside viewport margins, will be also exported. |
No | Displays the following prompt: Select point clouds or [?]: Specify the cloud to be exported, or select ? option. |
? | Shows the following prompt in the command line: Select an option or [Window/Last/Crossing/Box/ALl/Fence/WPolygon/CPolygon/Group/Add/Remove/Previous/AUto]: Select the cloud with one of the options. |
Info: NanoCAD is a simple, inexpensive, and yet powerful, CAD program for personal computer, that provides a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our program provides progressive, collaborative and customizable features to boost your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
