Drawing Comparison
Ribbon: Options – Functional Bars > Compare Files
Menu: Tools – Compare Files…
Menu: View – Toolbars – Functional – Compare Files…
Toolbar: Standard –
Command line: DWGCOMPARE
File comparison feature allows you to find the differences between the contents of the model space in two drawings: detect objects that have been modified, added, or removed in the compared drawings.
The Drawing Compare.dwg toolbar is designed to detect changes in different versions of drawings.
The comparison process determines objects that were changed, added or removed.
There is a number of limitations to using the Drawing Compare .dwg function:
- The function works only in the model space.
- Only .dwg files are supported.
- The following types of objects are not supported: OLE objects, cameras, geographic data, GIS objects from Map 3D, underlays (not dwg), images, coordination models, and point clouds.
- Changes of properties By Block and By Layer are not detected in nested blocks.
To compare files:
1. Start the Compare Files commto open Drawing Compare panel.
2. Click the button in the File1 field in the Select section. In the dialog that opens, select the first drawing file for comparison.
3. Do the same for the File2 field.
4. Set the Visibility, Color and Transparency settings for the compared files.
5. Click the Compare button.
A new document opens, displaying the result of comparing files based on the settings made.
You can control the display parameters of the comparison result both before the procedure and after displaying it on the screen.
Visibility
File 1 | Controlling the visibility of objects belonging only to file 1. |
File 2 | Controlling the visibility of objects belonging only to file 2. |
Shared | Controlling the visibility of objects belonging to both files. |
Text | Show/hide the results of comparing text objects. |
Hatch | Show/hide hatch comparison results. |
Color
File 1 | Color for objects belonging only to file 1. |
File 2 | Color for objects belonging only to file 2. |
Shared | Color for objects belonging to both files. |
Transparency
File 1 | Transparency of displaying objects belonging only to file 1. |
File 2 | Transparency of displaying objects belonging only to file 2. |
Shared | Transparency of displaying objects belonging to both files. |
Click the icon to open a dialog with information about the compared files:
Info: NanoCAD is a user friendly, low cost, and yet powerful, CAD software tool for personal computer, that provides a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our program supports creative, collaborative and customizable features to enhance your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and purchase later, if you like it.
