Convert tables
Converting .dwg tables to nanoCAD tables
Ribbon: Annotate – Tables > Convert .dwg Tables to nanoCAD
Menu: Draw – Tables > Convert table AutoCAD to nanoCAD
Toolbar: Utilities –
Command line: CONVERTTABLEA
The command is intended to convert .dwg tables to nanoCAD tables with the possibility of further editing using nanoCAD.
To convert a table, just call the command and select the table. The actual dimensions of the original graphics are multiplied by the scale of characters, therefore if you get a table with zero row height, you should change the scale of characters in accordance with dimensions of the original graphics.
Converting nanoCAD tables to .dwg tables
Ribbon: Annotate – Tables > Convert nanoCAD tables to .dwg
Menu: Draw –Tables > Convert table nanoCAD to AutoCAD
Command line: CONVERTTABLEN
The command is intended to convert nanoCAD tables to .dwg tables.
Info: NanoCAD is a simple, cheap, and yet powerful, CAD freeware tool for Windows, that allows an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our software ensures creative, collaborative and customizable features to raise your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and purchase later, if you like it.
