Copy of Objects Properties
Ribbon: Home – Properties > Match properties
Menu: Modify – Copy object properties
Toolbar: Main –
Command line: MATCHPROP, COPYOBJECTPROPS
This command is used to copy a part of the selected object properties or all of them and assign them to one or several objects.
You can copy color, layer, linetype, lineweight and other properties.
? Opens additional options to select objects.
Settings Opens the Property Settings dialog.
Select source objects or [?]: Select a source object.
Select destination object(s) or [?/Settings]: Select object(s) to assign the copied properties to or select the Settings.
Select destination object(s) or [?/Settings]: Select object(s) or press ENTER to finish the command.
The Settings option opens the Property Settings dialog box where you can specify the copied properties from the source object:
Parameters:
Basic properties
Color Switches on/off the color copying mode.
Layer Switches on/off the layer copying mode.
Linetype Switches on/off the linetype copying mode.
Linetype Scale Switches on/off the linetype scale copying mode.
Lineweight Switches on/off the lineweight copying mode.
Thickness Switches on/off the thickness copying mode.
Special properties
Dimension Switches on/off the dimension style copying mode.
Polyline Switches on/off the width and type of polyline copying mode.
Material Switches on/off the material copying mode.
Text Switches on/off the text style copying mode.
When copying a note properties, if the Text checkbox is unchecked, only the text style of the note will be copied, without the text itself.
To copy note properties without copying the text content, you can also use the Match Properties* button in the note creation/editing dialog.
Viewport Switches on/off the viewport properties copying mode.
Shadow display Switches on/off the shadow display copying mode.
Hatch Switches on/off the hatch properties copying mode.
Table Switches on/off the table style copying mode.
Multileader Switches on/off the leader note style copying mode.
NOTE: When copying leader properties from the menu Draw > Mleader, there is one feature:
• if the Text box is checked, then in addition to the text style, the leader text itself is copied;
• to copy properties without text, clear the Text checkbox.
You can also copy leader properties without copying text using the Match properties button in dialogs of creating/editing leaders.
Info: NanoCAD is an easy-to-use, low cost, and yet professional, CAD software tool for personal computer, that allows a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our freeware provides innovative, collaborative and customizable features to improve your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and buy later, if you like it.
