Delete vertex
Ribbon: Topoplan – Modify TIN > Delete Vertex
Menu: Ground – Editing TIN > Delete Vertex
Ribbon: Editing TIN > Delete Vertex
Command line: NG_MESH_VERTEX_DELETE
The command deletes a vertex from an existing surface (Submesh or Polyface mesh) and rebuilds triangulation.
The vertex to be deleted is highlighted in red.
To delete a vertex:
- Run the command.
- In response to the prompt in the command line:
Select vertex to delete
select a vertex. The selected vertex is deleted, and the triangulation mesh is rebuilt.
Surface before deleting the vertex Surface after deleting the vertex
- Several vertices can be deleted in succession. Pressing ESC button ends the command.
Info: NanoCAD is a simple, affordable, and yet professional, CAD platform for PC, that provides an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our program supports innovative, collaborative and customizable features to improve your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and purchase later, if you like it.
