Update Field
Ribbon: Insert – Data > Update Fields
Menu: Tools – Update fields
Context menu of Text and Multiline text: Update field
Command line: UPDATEFIELD
Update field manually to see the latest value. Select needed objects and press ENTER , fields in selected objects will be updated.
Select field and open the context menu in Text or Multiline text, find there Update field. Field will display the current value.
FIELDEVAL system variable controls how fields are updated.
