Dynamic Input
Status bar: Button
Hot key: F12
Dynamic input displays the command interface near the cursor in the drawing area. At the right time, current prompts, command requests, input fields, lists of selectable keywords, dimensions of edited geometry are displayed next to the cursor.
Dynamic input consists of three functional parts:
- Pointer Input;
- Dimension Input;
- Dynamic Prompts.
You can adjust them or switch them off in the Dynamic Input section of the Options dialog.
Dimension Input
Dynamic dimensions are displayed when creating and editing lines, arcs and circles. The values of dynamically displayed dimensions can be edited, which makes it more convenient to draw and edit, when the exact distances, dimensions and angles of segments are known.
When constructing a linear segment, an arc segment or a circle, their linear and angular dimensions are displayed on the screen relative to the previous point. Dimensions are displayed with a thin dashed line. With the moving of cursor in the drawing, the values of dynamically displayed dimensions continuously change reflecting the current dimensions. By pressing TAB key it is possible to pass to the desired dimension value to edit it from the keyboard. Upon the input completion, press ENTER.
When moving the cursor to the grip of preselected objects, the dimension values associated with it are dynamically displayed on the screen. When moving the cursor to the grip belonging to several selected objects, the dimensions of each object associated with this grip will be displayed.
When selecting the object grip, the values of dynamically displayed dimensions become available for editing. By pressing TAB key, move to the desired value. Enter a new value from the keyboard.
To move to the next dimension value, press TAB. The edited dimension will fix its value, and the lock icon will be displayed in its right part.
To complete the editing, press ENTER.
Pointer Input
When a point is requested by a command, you can enter its coordinates in the tooltip box near the crosshair, where the current cursor coordinates are shown.
By toggling the TAB key, switch to necessary value to edit it from the keyboard. Press ENTER when done.
Dynamic Prompts
Dynamic prompts provide an alternative way to enter command parameter values. In the tooltip field near the cursor, requests and prompts of the active command appear, necessary to complete the command. Data can be entered in the dynamic prompt fields instead of the command line. You can enter command keywords and requested numeric values.
The list of available values and options can be expanded by pressing the DOWN ARROW key on the keyboard. Then choose the desired value with an ARROW keys and press ENTER.
