Scale
Ribbon: Home, Draw – Modify > Scale
Menu: Modify – Scale
Toolbar: Modify –
Command line: SC, SCALE
This command is used to decrease or increase the size of the selected objects whilst retaining their proportions (the scale factors along the X and Y axes are identical). If the scale factor is more than 1, the objects are increased in size; if it is less than 1, they are decreased.
? | Opens the additional options to select objects. |
Copy | Scaling copy of the selected objects. |
Reference length | Scaling the selected objects towards the reference line whose length is a single scale factor and a new length for the reference line. |
Points | Scaling the selected objects towards the reference line whose length is a single scale factor and a new length for the reference line, specified by two points. |
Select objects or [?]: | Select objects. Press ENTER when the selection is finished. |
Specify base point: | Specify the base point. |
Specify scale factor or [Copy/Reference length]: | Select the Reference length option. |
Specify reference length: | Specify the first point. |
Specify second point: | Specify the second point. |
Specify the new length or [Points]: | Select the Points option. |
Specify first point: | Specify the first point. |
Info: NanoCAD is an easy-to-use, low cost, and yet powerful, CAD application for Windows, that provides an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our software supports progressive, collaborative and customizable features to improve your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and purchase later, if you like it.
