Arc length dimensioning
Ribbon: Home, Annotate – Dimensions > Arc Length
Menu: Dimensions – Arc
Toolbar: Utilities –
Command line: MDIMARC
This command creates an arc length dimension. Arc length dimensions measure the distance along an arc or polyline arc segment.
To differentiate between the arc dimensions and the linear or angular dimensions, the arc symbol is displayed above the dimension text by default.
For dimensioning the arc length dimension:
- Start the Auto command.
- Select the arC option in the command line or context menu.
- Place the cursor over the arc to show its dynamic highlighting. Left click to confirm the dimensioning:
- Left click to fix the chosen location of the dimension:
For dimensioning the lengh of Cicrle part:
- Select the arC option in the context menu.
- Place the cursor over the arc to show its dynamic highlighting. Click at the start point of dimensioning part of circle.
- Place the cursor over the arc to show its dynamic highlighting. Click at the end point of dimensioning part of circle.
- Click to fix chosen location of the dimension.
Info: NanoCAD is a simple, inexpensive, and yet powerful, CAD app for PC, that allows an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our software supports groundbreaking, collaborative and customizable features to raise your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
