Multileaders
Ribbon: Home, Annotate– Leaders – Multileader
Menu: Draw > Mleader…
Toolbar: Mleaders –
Command line: MLEADER
Multileader is a drawing drafting object and, as a rule, is a straight line or a spline with an arrow at one end and multiline text object or block at the other. A text or block are connected with the leader line by a short horizontal line – landing.
The visual representation of a multileader, as well as its other parameters, can be edited when it is being created or on the Properties functional panel. For example, it is possible to show or hide a landing, leader lines, change the arrowhead appearance, create a frame around the text, change the point of block attachment, edit parameters of multiline text, incl. set background mask, etc.
It is convenient to adjust the multileader location on the screen with help of functional grips.
Leader landing first | Start constructing with specifying the location of the multileader landing. |
Content first | Start constructing with specifying the location and entry of the text or specifying the block (depending on the type of multileader content specified in the options). |
Leader arrowhead first | Start constructing with specifying the location of leader line arrowhead. |
Options | Additional options for constructing the multileader. |
Leader type | Specify the leader line type: straight, spline or not display the leader line. |
Leader landing | Specify whether to display the multileader landing and the landing line size. |
Content type | Specify the content type of the multileader being created: block, multiple text or no content. |
Maxpoints | Number of points for the leader line. By default 2, i.e. one leader line segment is created. |
Specify the location of leader arrowhead or [leader landing first /Content first/Options]: | Query for the location of the arrowhead or the content, depending on the selected order of multileader construction. Additional options can be adjusted by selecting Options. |
Define the option or [Leader type/Leader landing/Content type/Maxpoints/First angle/Second angle/Exit options]: | Displayed when Options is selected in the previous query. |
Info: NanoCAD is a simple, affordable, and yet powerful, CAD application for PC, that allows a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our freeware supports progressive, collaborative and customizable features to boost your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
