Command line: CHPROP
Changing objects properties using the command line.
Command options:?
Opening additional options to select objects.
Select objects or [?]:
Select objects for editing, press ENTER.
If several objects selected have different values for the property to be changed, the <*varies*> value is displayed as the current one.
Enter property to change [Color/LAyer/LType/ltScale/LWeight/Thickness/PLotstyle]:
Specify the property to be changed.
Color
Enter new color [Truecolor/COlorbook]
Changing color of selected objects.
Truecolor – selecting color from the color palette.
COlorbook- selecting color from the downloaded album.
LAyer
Enter new layer name <0>:
Changing layer of selected objects.
LType
Enter new linetype name :
Changing linetype of selected objects.
ltScale
Specify new linetype scale <1.00>:
Changing linetype scale.LWeight
Enter new lineweight :
Changing lineweight of selected objects. Lineweight should have a value from the standard range.
Thickness
Specify new thickness <0.00>:
Changing thickness of 2D object by Z axis.
It is not possible to change thickness of 3d polyline, dimension or layout viewport.
Plotstyle
Changing properties of named plot styles.
Available only if named plot styles are used.
Info: NanoCAD is a simple, affordable, and yet powerful, CAD software tool for personal computer, that delivers an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our program ensures innovative, collaborative and customizable features to boost your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and purchase later, in case you like it.
