System Requirements
Operating system | Microsoft Windows 11 Microsoft Windows 10 (32- or 64-bit); Microsoft® Windows® 8.1 (32- or 64-bit). |
Processor | Minimum requirements: 2 GHz. Recommended: 3 GHz or higher. |
RAM | Minimum requirements: 4 GB. Recommended: 16 GB and more. |
Monitor | Minimum required resolution: 1920×1080. Recommended resolution: 3840 × 2160 (supported in Windows 10, 11). |
Graphics | Minimum requirements: graphics processor with 1 GB video memory. Recommended: graphics processor with 4 GB video memory (supports OpenGL 2.1 or DirectX 11). |
Hard disk free space | 7,0 GB and more To work with large point clouds, it is necessary to take into account their volume and quantity when choosing a hard disk. Estimation of the amount of point cloud data can be carried out according to the following table:
Volume of points in a cloud Size in megabytes per HDD 1 mln. 16.02 100 mln. 1611.56 1 bln. 16313.00 2.5 bln. 40782.50 It is recommended to store point clouds on SSD disks to speed up the work. |
Network | TCP/IP protocol should be run on the license server and all work stations where the applications using network licensing will work. |
