Clip Undo
Ribbon: Point Clouds – Clip and Section > Undo Clip
Menu: Point Clouds – Clip > Undo
Toolbar: Point Clouds > Undo clip
Command line: NPC_CLIP_UNDO
You may clip the cloud repeatedly. Clip Undo cancels the last clip of the point cloud.
Select view: | Select needed view to cancel the last clip. This request is displayed if there are several viewports in the model space. |
NOTE: CLIP UNDO command is not related with standard UNDO command.
Info: NanoCAD is an easy-to-use, inexpensive, and yet powerful, CAD freeware tool for personal computer, that delivers an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our tool supports groundbreaking, collaborative and customizable features to improve your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
