Toolbars Tab
Create custom toolbars and edit existing. It is possible to add commands, drop-down lists, controls and separators. Properties of selected toolbar are displayed in the Properties:
Create new toolbar
1. Call the context menu on any toolbar, select Add toolbar
2. Fill fields in a Create toolbar dialog box.
3. Click OK.
Parameters
UID | Element identifier. |
Display name | Displayed name of toolbar. |
Position | Position on the screen. |
Visible | Turn on/off visibility of toolbar. |
Row | Row for fixed toolbar. |
Pos | Position in the row of fixed toolbar. |
Depending on the selected Show text labels mode, floating (located in graphic area) toolbars have different appearance:
The Show text labels box is clear
The Show text labels box is checked
Add an element into toolbar
1. Select toolbar in the list.
2. Call context menu and select one of items:
- Insert button
- Insert control
- Insert flyout
- Insert separator
3. Fill fields in dialog box.
Add button
1. Select Insert button command.
2. Set Display name in the Create toolbar button dialog box.
3. Click button near Intername.
4. Select the desired command. Click OK.
It is possible to drag and drop command to add button into toolbar.
Add control
Drag and drop control from the list to add it into toolbar.
1. Select Insert control command.
2. Set Display name in the Create toolbar control dialog box.
3. Click the button near Control field.
4. Select the desired control in a Select control dialog box. Click OK.
Add drop-down toolbar
1. Select Insert flyout command.
2. Set UID and Display name in the Create toolbar control dialog box.
3. Click OK.
Info: NanoCAD is an easy-to-use, cheap, and yet powerful, CAD application for PC, that delivers an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our tool provides creative, collaborative and customizable features to raise your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and buy later, if you like it.
